Stud pattern and tires on new Polo GTI
  • Stud pattern and tires on new Polo GTI
    Does anyone know enough about the stud pattern and size of the rubber and rims of the new Polo GTI, to tell me if they will fit onto the current Polo GTI?
    Cheers!
    DCN
    i thought the new polo gti uses the same alloys as the golf gti mk6?
      comes with denvers again, so will either be 5x112 or the same 5x100
      Originally posted by Preen59
        the ones in the Golf are 18" - the ones in the Polo will be 17" - they just have the same look but they are different in size - and AFAIK the golf is still 5/112 and the Polo is still 5/100 so they wont be interchangeable - if you want the bigger rim in a different PCD and offset value then you will need to look for replica's when those become available
          just downloaded the polo brochure in german- the 16'' alloy wheel options are 5x100 16x7j, with an offset of 46mm.
          17 inch wheel options is as above, but 17x7j.
