I'm going to TRY and write up some info on Adaptation Channel Tuning.
I have a habbit of getting these things slightly wrong or using incorrect terminology, so please feel free to correct me and if this thread gets popular, I'll amend the information in this Post.
Disclaimer: Playing with any of these applications could cause damage to your vehicle, any changes you decide to make have nothing to do with me. I take no responsibility for the information in this thread and it is only provided for research purposes.
What are Adaptation Channels and Adaptation Tuning?
Before I try to explain what Adaptation Channels control, let me tell you what they don't control:
There are a few areas of a cars computer control system. When you buy a tune from one of the many Chipping / ECU / Computer Flash companies, you are buying an edited version of the OEM computer program. They don't play with every little setting, just the ones that relate to the engine settings and in our case, turbo settings. They utilize all the normal instruments (like the MAF) to make the new tune work with the normal car's operation.
The 'maps' they create differ from company to company, each mapping how the power is delivered in slightly different ways. This is what I will call dynamic, as it works across different areas and with the cars normal adaptation settings.
So what are adaptation channels?
Adaptation Channels are another area of control for the ECU. These are stored in Semi Volatile memory (won't go away if you turn off the ignition, but won't be there if you pull the battery for 20 minutes).
VAG 1.8T's of a certain vintage have these channels which allow tweaking of certain parameters across the engine range. These are NOT dynamic, in that you can not make changes to 2000rpm alone, they are always used.
What settings are there?
Here are the 14 channels (2 of which are unused):
01 Idle Speed Offset
02 Fuel Tweak - Increasing Loads
03 Fuel Tweak - Decreasing Loads
04 Startup Up Fuel Enrich
05 Warmup Up fuel Enrich
06 Lambda Regulation
07 Additive Offset To Speed Limiter
08 Secondary Fuel Tweak
09 Ignition Timing Offset
10 Primary Fuel Tweak
11 Unused
12 SEL Scaling
13 Control Bits (Unused)
14 Idle Torque Additive Offset
Now the big question: What does each channel do?
I have found it very difficult to find a comprehensive guide to these control blocks. Why? Because if you mess with them you can do some serious damage. All applications are free, therefore no manual, no support. These settings allow you to control the car's settings, not tweak the tune you bought. There are little bits of information here and there, I'll link the good ones below.
If you can do serious damage, why are you playing with them Fool?
Because 1: I like to play and 2: If you take care and go slow, you can get more out of your car without spending any money!!!
Some general information:
What software options are there?
Lemmiwinks, V-Tune, CustomSettings and Unisettings. There are probably more.
Is there a difference between them?
V-Tune is designed for APR'd vehicles only. This software is not compatible with the software map on our little Pog. If there are enough people interested, we may be able to ask nicely for them to make a version for us.
V-Tune has a feature that allows the boost to be turned up, this is NOT available through any other software. My understanding which is still wanting is that the V-Tune software controls boost in a different way to addressing Adaptation channels.
The others all look and act pretty much the same. I used CustomSettings as it worked for me and has the ability to save files. I like the idea of saving a file before I start (even though the settings are very basic).
So I don't need a tune, I can go and make my own maps, right?
No. A map is more than just changing a value, there is a lot of R&D, time and expert industry knowledge that comes into play when making a map for a vehicle. The settings in these applications do not give anywhere near the control that the tuners do. What can be done is pretty small and it is STRONGLY advised not to change anything unless you know what you are doing.
Is there a procedure for making changes to these settings?
Yes. Log your car with Vag-Com or another application to see what your car is doing. If you feel that the car is operating well, with no symptoms of issues, you can make changes to the Adaptation channels.
The general rule I have found is Log, make small change, Log again. This ensures you don't go messing things up.
What are my plans?
I'm not sure yet. I don't yet know enough to make any changes accept to the Ignition timing offset. I don't want to try and explain exactly what is does as I will no doubt give an un-suitably un-technical description to something that is technical.
Some Links:
Lemmiwinks S4 Wiki
Lemmiwinks Non Guide - Guide
Adaptation Discussion on Fortitude forum
Description on Vortex
Enjoy...
11 Unused
12 SEL Scaling
What are my plans?
Some Links:
Lemmiwinks S4 Wiki
Enjoy...
