Tyre Pressure indicator. Gimmick?????
  • #31
    Originally posted by Glide_GTI View Post
    to answer a few questions here, I spoke to derek about the sensor, heres how it works.
    its actually a part of the ABS system, it detects the 'pressure' by measuring the rotation speed of each tire, so when you get a flat, it will notice a change in the rotation speed compared to the other three, if you get a flat in all 4 at once, it wont be able to detect pressure drops
    This is how it works, should answer some questions.
    aus liebe zum automobil
    • #32
      So the answer is NO it cant tell if the wheel is changed.
      For Sale 2006 VW Polo GTI
      Have a Look
      CUSTOM CODE
      Phase 2
      • #33
        If you have different size wheels put on then yes it go off. Interesting note about when I had my new tyres put on. I had them put on on a Wednesday, drove to Canberra via the coast on a Friday, on the way to Thredbo on the Saturday the monitor went off. At the next servo I pulled over, check tyre pressures, they were all fine. Made some adjustments and then reset the monitor, haven't had it go off since.
        • #34
          Mine has gone off 3 times when pressures have changed in a rear but not when I blew a tyre..?? go figure...
          gtigrl want to go faster
          2006 Polo GTI
          • #35
            tyre pressure indicator
            I was out in the middle of the sticks last night,
            On a highway through the bush, NO street lights, super narrow one lane street.
            I freaked out when the tyre pressure sensor came on. But got out and everything looked okay. so i kept a close eye on the tyres (stopped every 5 mins) then finally found a service station and filled the tyres up a bit more.
            Thing is that none of the tyres were really low, but i took the opportunity to lift pressures up a bit then reset the sensor
            GTI. Leather.
            tint,Eibach pro-kit,Whiteline adjustable swaybars,Forge s/brace,BMC,Forge T.I.P & D.V, Cupra R, APR. EBC & 3''dump pipe
            • #36
              OK so its not a gimmick, ive had it go off twice in the last week
              1st time was when i thought it was flat but it wasnt and i found an egg in the side wall.
              2nd was last night when i had a nail in my tyre.
              Have a Look
              CUSTOM CODE
              Phase 2
              • #37
                That sucks dude, but at least it can probably be repaired. You are now a believer.
                • #38
                  If you hit a puddle or still water at high speed it goes off. So aquaplaning sets it off.
                  Originally posted by Kai
                  And then dont forget the most important mod for gays.
                  Blow off valve - 300
                  • #39
                    Tyre Pressure Indicator
                    Really?????? thats new hehe had no idea !
                    P.S how unbelievably well does the GTI handle in the wet. Soo much grip!!
                    GTI. Leather.
                    • #40
                      Sorry to dig up and old Post.
                      I have just taken all my rims off on the weekend to sand and spray. My friend stupidly sprayed over the back of the Tyre which we marked the location of the Tyre on the car. lol idiot haha
                      Anyway i had noticed driving into work today that the car swayed a little which is to be expected and the steering wheel had a little and only a little shutter at 100k.
                      The Tyre Monitor display came on at about 105 on the freeway. I pulled over checked the tyres. All have perfect pressure and were not going flat. Only thing I can think off is that the wheels are out of balance which i knew would happen and this has set off the light.
                      It does turn on when I stop and start the car imediately now. I have not used the VAG on it yet as the laptop died.
                      Any thoughts?
                      2006 POLO GTI -------RUS7Y-------Custom Cat Back + More to come
                      • #41
                        Read earlier posts regarding this. It doesnt refresh fast enough to go off if a tyre blows.
                        Surely you dont need a sensor to tell you have blown a tyre.
                        • #42
                          Any thoughts?
                          Is a wheel loose Had my wheels rotated once and car felt funny afterward. Turned out the **** that did them put one on crooked and it had come loose. Bl++dy Holdens with tight centres.
                          • #43
                            Originally posted by Hillbilly View Post
                            Is a wheel loose
                            Its a possibility,
                            I thought we we dropped it the back left looked a little crooked but after staring at the back of the car and comparing it looked ok. Ill have to check the nuts when I get home as I don't have the tools with me. Still scattered all over my garage
                            • #44
                              Its a possibility,
                              I would grab it and shake it before I went home or you may not get there
                              • #45
                                Its a possibility,
                                No wheel brace in the boot?
