I had a wheel alignment done after my recent suspension upgrades:
- Front Whiteline Sway
- Coilovers
- Rear Control Arm bushes (Whiteline)
- 312mm front brakes
After having the front left bearings on the top of the suspension tower break soon after the new suspension was installed, I had them replaced and the shop organise the wheel alignment so it was sorted straight away.
The shop had issues with the allignment, the specs were fine on the machine, but then when back on the road, the car is pulling to the left. The gent from the allignment shop said it was an issue with the chassis or subframe, but I had not experienced this previously.
I'm wondering if this has to do with the play that Eddy has found, or if someone can suggest if there is normal adjustment required that this gent may not be aware of as he does not know the Polo?
Any advice or info would be appreciated.
- Coilovers
