Fscking centre caps!
  • Fscking centre caps!
    Just lost a second wheel cap in a month. How the hell do they come out so easily, it took a decent push to put one back in. Or is some d*ckless piece of sh*t stealing them somehow?
    Anyone got a solution such as gluing them in place?
    (Off to buy a set of 4 from ebay )
    MY11 Skoda Octavia vRS wagon 147TSI DSG
    Generally it's the fronts that are the main problem.
    It's caused by the heat from the front calipers heating up the wheel,which expands/contracts at a different rate to the plastic cap.
    Solution is to Silastic them in.Problem solved.
      Lost one at the track per chrissie, cost $13 from VW for a new one, hardly expensive.
      Apparently jap centre caps fall out every 15,000 kays and they charge $45+ a pop...
      06 > 9N Polo GTi
        Heh, I've lost a front and a rear now, both on the same side
        Yeah last one only cost me $13 from VW, just found 4 on ebay for $10
        Will keep spares in my glovebox.
          I've lost all four from my various track outings, 4 x $13 = Farking expensive. According Petrina, my car is now ruined
          aus liebe zum automobil
            Here you go!
            $10USD for 4, posted
            I'm just going to keep a steady supply in my glovebox from now on!
              Originally posted by tooch View Post
              Here you go!
              Did you make sure they are the correct ones? When I last spoke to VW Parts they said they're lots of part numbers for them. If so I think I'll get a set of 4. Thanks for the link
                They are the closest looking ones I could find on ebay. Says it fits the 9n3, and they look the same. Some of them have a little cutout on one side, and others have a different looking logo.
                I'll see if they fit when they arrive
                  let me know if they fit/look the same as VW ones when they arrive. I need one too.
                  Daily: 2010 VW Jetta Highline
                    Will do! They might actually be OEM ones anyway, as that seller seems to sell mostly OEM VAG parts.
                      so did these centre caps fit?
                      im keen to order some if so
                        Yeah they did mate, and *touch wood* I haven't lost any of those ones yet! They may be a tighter fit than the factory ones, not sure.
                          They'll be a tight fit when new.
                          It's when they've had multiple heat/cooling cycles that they become loose!
                          Silastic is the answer.
                            thanks guys..have ordered a set.
                            when installing...do they just press in or is there something else to it?
                              So you guys getting the complete centre cap
                              Or just the sticker and glueing it?
