pod filter = increase fuel consumption?
  • pod filter = increase fuel consumption?
    Hi all,
    After installing a pod filter onto the Polo GTI, I've noticed that fuel consumption has increased quite significantly....
    Does installing a pod filter increase fuel consumption? Should I be looking to reset my ecu so the engine can remap and relearn?
    Thanks in advance all!
    I would say it should be better on fuel driven under the same conditions..
    The new induction roar is addictive, id say you have been a leadfoot.
      Depends, it can increase fuel consumption and reduce power if its not getting the cool air feed it needs.
      Sucking in hot air will only increase the fuel consumption (especially in stop/start traffic where heat soak will play a part).
      Is the pod filter open, or is it shielded with a cold air feed?
      Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
      Current Ride: Evo 8 MR, Fabia MK3
        the pod sits in the stock airbox however the top of the airbox has been removed...
        has anyone gotten their ecu reset after an intake modification? is this necessary?
          ECU reset is a simple matter of disconnecting the battery for a few minutes.
          However, sitting the pod in the stock airbox with the top removed is going to allow it to suffer the effects of heat soak in stop-start traffic. I would look at fully enclosing the pod if possible.
          The K&N Apollo POD kit is the ideal solution for this.
            If you are going to have the top of the box open, I'd think about removing some of the rubber that forms a seal around the bonnet. This should hopefully allow more of the hot air under there to escape.
            There may be side effects or implications, but from memory, Plautos had done this as had someone else...
            Could be hotter air, maybe try covering the engine side of the opening more. Maybe a pic of your setup may help...
              If you do not enclose the filter completely your are also risking a fine.
              MK4 GTI - Sold
              MK5 Jetta Turbo - Sold
                I had this setup on my car. removed the rubbers around the hood at the top.
