Brand new car probs...
  • Brand new car probs...
    Hey VW-ers,
    I am the proud owner of a brand new Polo GTI (1000k's) and have two problems:
    1) Regular metallic type knock against driver side footwell (sounds like when you flick a ruler on a table), upon reversing out of my drive which is on slight slope, with some slight pressure on brakes.
    2) Upon pulling out of the garage this morning, found 3 drops of clear oil with a yellow tint to it.
    Took the car back to dealer who says they placed it up on hoist and couldn't find anything, let alone any signs of oil. When home, jacked the car up and found sings of oil leak straight away. Leads me to believe they did nothing???
    Cleaned up oil, went for a long-ish drive today, and hey presto, oil found in the same spots under car (anti-rollbar, and vicinity). Any help/suggestions would be great to have a bit of ammunition to take to the dealer this week.
    Cheers,
    Con.
    best bet to take it back and go into the workshop and point at it when they have it in the air
      Take a photo of the oil, take it in and ask them how many times mummy dropped them when they were little.
      Edit: Yea I'm sick of incompetent mechanics who can't be bothered doing a proper job.
      Originally posted by Kai
      And then dont forget the most important mod for gays.
      Blow off valve - 300
        sounds like a similar issue 2 other cars had - leak around CV joint. jack it up and wrap the CV joint in some paper and leave it wrapped for a while (30minutes??). remove paper and check for oil stains.
        alternatively, visually inspect the CV joint for leaks.
          Got home tonight and jacked the car up. Noticed some drops of oil in 2 places, both in the same area as both inner cv joints. Looked a joints, and noticed both seemed to have a fine film of oil on them. The oil was not on the boot(s) though, just on the metal section prior to entering gearbox/diff. Could you please forward link to relevant section of forum or provide details of the 2 other similar cases you mentioned.
          Cheers,
          Con.
            Cheers,
            Con.
            From what you have written there, it sounds to me like the output seal on the gearbox. Seals may not be in properly, or could have a small tear in them. If you are not happy with the first dealer, get another dealer to check it out.
              I may not have correctly described where oily film was on cv/drive shaft. The area with residue looks to be a flange (several torx bolts) just after cv boot, which the joint bolts onto. Hope this helps.
              Con.
                those 2 cases are not from this forum or on the internet. it happened to two of my friends.
                in both cases, the description of the type of oil/liquid you mentioned matches theirs and the leak was seen at the CV joint.
                similar to the 2 cases.
                since your car is brand new, bring it back and show them the stain on the CV joints. the fix should be a pretty straight forward replacement of the said part.
                as for the first problem - is your suspension stock? try one test -
                1. find an empty car park
                2. reverse the car fairly quickly
                3. hit the brakes hard
                do you hear the same knocking sound? if you do, it could be your front sway bar knocking against something. have them check that (perhaps your drop links are defective??)
                hth.
                  Sound like your driveshaft seals. Knocking noise may be your sway bar link, or brake pad moving around in caliper when your reverse. Or drive shaft not seat in diff properly and move about causing seal to leak & noise.
                  Test sway bar is easy , open one door, garb both hands bout the roof part and shake car left to right (by push & pull), built up enough momentum and you will hear sway bar link/s knock if there are any.
                    In reply to jesum, I've found a similar problem on vwvortex where a couple of owners have had transmission oil leak into innner cv's. Their problem was caused by defective driveshaft flange seals. Would this be the problem your 2 friends had with their cars, and if so, did the VW dealer cause any dramas with acknowledging problem and sorting it?
                    Cheers,
                    Con.
                      Your yellow tint oil i suspect is tranmission oil. I think a driveshaft flange seal leaking there. No hesitance should be taken by the dealer to replace that. They should have such a thing in stock depending on which side it is the part number will be for an 02J box even though yours is 02R that part is exactly the same.
                      Good luck and i hope it doesnt put you off , so much fun to be had
                      Jmac
                      Alba European
                        hmmmm Jmac could be right because it's unlikely for BOTH CV joints to fail at the same time in a brand new car. as long as your car is stock, the VW dealers won't give you any trouble.
                          Thanks guys,
                          To answer jesum, the car is going on one month old, and is bog standard.
                          The reason I am a bit apprehensive about taking it back to the dealer is that when the problem first arose, I took it there and described what had happened. They took it into workshop and said they put it up on the hoist to check the underside, and the head meachanic said there was not one sign of an oil leak, or any other problem upon inspection. As mentioned previously, I found the oil/leak straight away. I just want to know why did they bull**** to me?
                          This is why I am a little hesitant about the dealer acknowledging there is a definite problem, and fixing it.
                          Anyhow, thanks again guys. Will keep you posted regarding 1month/1000km service.
                            Hey GTI PAPA,
                            sounds suspiciously similar to my problem..bot in terms of the oil, and the mechanics!!
                            see for my posts on this page
                              Just park it in front of the dealer doorway, with a sign pointing to the puddle of oil beneath the car, and another sign saying the dealer won't fix it.
                              Should help get it fixed without delay
