cam shafts
  • cam shafts
    has anyone on here upgarded there cam shafts? was just curious. some of them from this site http://www.intengineering.com/Cat-Ca.../sc262362-1-2/ have some interesting options. some of them produce more power at top end which could be usfull, while im guess at a sacrafice to low end torque, which could help with wheel spin. any thaughts? oh and incase people are wondering i know ther for mark 4 golfs but id asume the 1.8t cam shafts would be similar/same.
    " I wait I resolution derive pleasure this " latest spammer post
    Hey mate, Plautos has a set of those on his little weapon.
      awsome thanks ill im him.
        Well according to the website it says if you plan to get a bigger turbo then its useful.... I assume with the current cams its tuned for the K03 as much as it can?
          I think we can source Shrick cams but not too sure if it's billet or grinned cams...
            Anyone else up for another glorious group buy
              I'm using the 3651.
              The engine revs faster and develops more power at hi-rpm.
              Check out my Polo's thread, there you will find dyno charts, after and before the cams.
              SILVER TEAM
                Be good to see some figures after these cams are done as im sure our good friend plautos knows if you go too agressive on cams you can bleed off compression, and lets face it compression is the key. This of course can be dealt with buy changing the structure of the piston or decking the block.
                Functionality is another thing.
                Interesting thread to be started here guys good work
                Jmac
                Alba European
                  Jmac
                  Yeah Jimmy, great points! I just looked at Mikes link and it says there are 3 different hydraulic grinds, 2 very aggressive by the sounds of things and the other one more mild and street friendly which are the same as Plautos 3651's
                  By my calculations about $780-800 delivered to OZ.
                    Need to know the lift , havent looked at our friend Plautos thread lately but does he have any feedback on the functionality ( if he has done it of course) and how it goes?????? im keen to find out as i have a really good connection with a top drag builder and he eats and sleeps cams, ive already mentioned the 1.8T to him so yeah m keen to hear.
                    Jmac
                    Alba European
                      plautos replyed that his definatly helped on track at high revs , but probably wouldnt be worth day to day. but then again the way some of us drive ours it certainly couldnt hurt. i know i wouldnt say no to more top end, and lets face it 780-800 delivered isnt that much of an ask.
                      Ps: plautos if you in any way didnt want me to quote you, let me know and ill edit my post.
                      hmm group buy might certainly be in contention, since i got my tax return.
                        I never change a camshaft on a vw, but is it straight forward swap like lift the cam cover, pull out the old cam and fit the new ones?
                        Just wondering how much would that cost to install it...
                        I am interested in as well, but do we need new software for it?
                        Hmm....
                          Hmm....
                          these are some of the same questions i had. aparently plautos is using apr k04 software (by no means em i endorsing a chip here ) and he has scene gains. so im guessing not. maybe someone with more technical knowledge could shed some light on the dificulty rating on changeing a vw cam shaft.
                            A fair bit more to it than lifting a cam cover off mate im afraid, you have the valve timing to set, timing belt off, and a chain runs between the 2 cams which too has to be set up, there is a cam chain adjuster in there too. You can get this seriously wrong. Not for a novice .
                            Jmac
                            Alba European
                              This is just an opinion but cams are the last thing I'd be replacing on a 20VT. I'd spend money everywhere else before opening up the motor.
                              Invariably they produce power where it's least accessible.
                              A cam in a normally aspirated motor makes sense but multivalves flow well by design so there's less to be gained, especially in a daily driver.
