Vacuum over electric windows ??
  • Vacuum over electric windows ??
    Any one have a clew where to look with a window tha is stuck up please fuses or hoses or software fault ??
    where do we start ?
    1,6 ohc polo petrol auto .
    TC
    Try lowering the windows using the key in the driver's door option, could be a faulty window switch
      should be labled in the fuse map on the panel that covers them i think?
      try the key...failing that, pop the door skin off and check if the wiriing is still connected
        When you hit the switch, soed anything happen? A noise from the door at all? This would tell you whether or not the motor is getting power.
        If you've got no power, or no noise at all, check your fuses.
        If it does make a noise but no further action, you've got real problems. Then,
        I'd say your window regulator is stuffed. Not real tricky id you know what you're doing, but not something i'd suggest you take on with limited skills.
          I reckon they might have resettable fuses. In case of an overheat.
          Does the other side work?
          I would take the door apart if it were me and check at the motor after confirming there's no fuse.
