Okie where to start.
Was doing a pad change on the drivers side after completing the passenger side when I noticed fluid dripping on the ground. After looking around the engine bay I found it coming from the brake fluid resy.
I then took the car for a drive to check the pads when the car started to make a horrilbe streching sound from the drivers side. After going in reverse the noise went away and I headed home...
To discover brake fluid everywhere on the underside of the car and lower half on the drivers side of the engine bay. Also the rubber cap for the bleeder has gone.
There is no adverse brake effects at the moment.
Anyone have any idea's what has happened and can it be fixed???
Thanks,
Matty
Thanks,
Matty
