Polo GTI - White Smoke...
  • Polo GTI - White Smoke...
    Hi Guys,
    I have a problem with my cabbie... after a drive, while idling there is white smoke after a few seconds its dies down, give it a few revs and it gives a few puffs...
    checked the oil level - ok
    it definately aint condensation... any ideas. got a booking next week at my preferred local dealer
    only mods are de-cat and pd160 intake..
    lamda sensor?? filter?? anything valves?
    car has 42 000 km
    have discussed on my local forum...
    guys r not to sure, i know it aint my turbo, i get no weird sound or anything, no power loss.
    im guessing may b seal somewhere between IC and turbo, or seal in Turbo itself
    any ideas any1?? do u think its safe to drive for the next 5 days?
    Originally posted by jueshen View Post
    Hi Guys,
    car has 42 000 km
    White smoke = steam = water.
    I don't know enough about these cars to know how it would be getting in though.
      I always thought white smoke was a head gasket issue.
      Though a mate had white smoke and it was transmission fluid somehow getting through some sort of valve ... was an auto Commodore so no idea if it's possible for it to happen on a caddy.
      Good luck with it.
        Sure is buddy! From the gasket not properly sealing the water galleries that run between the head and the block, and allowing water to seep in to the combustion chamber.
        I'm also wondering if a dodgy seal in the turbo could allow the water cooling to enter the exhaust housing, but I don't know enough about turbos to say.
          no smoke last night
          no smoke this morning
          mayve it was the change of fuel...
          im still getting it checked anyway
          atleast i dont have to stress anymore.... until next week that is
            no smoke last night
            you sure it didnt just have condensed water in the exhaust? did you leave it outside at night?
              go give it the floggin of its life than check your oil. It's it's milky/cloudy, it broken.
              More constructively, the oil will be a sign of water in your engine as previously described, unless it's around your turbo. Which is still a better result than in your engine.
              Daily: 2010 VW Jetta Highline
                im almost sure it was not consendation
                took it for a hard drive car still feels awesome!!
                no milky oil, no drop in oil level, no drop in coolant/water level
                no more smoke...
                im sure it was the change in fuel brand and octane...
                but to be safe i will have it checked out...
                  no more smoke...
                  Water in the fuel?
                  White smoke is nearly always water.
                  Blue is oil.
                  Black is excess fuel.
                    maybe poor fuel?
                    im not too sure
                      has the coolant level dorpped? if so it may be the EGR cooler. just a thought. let lus know what the dealer says............
                        Pressure test and Cylinder leak test will give you the answer, no if or buts. If available do a TK test which will detect CO in the coolant, great test as well
                        Good luck and hope its not that bad
                        Jmac
                        Alba European
                          thanks for the advice, car is going in on 3rd June
                          will let u all know
                            Maybe it means your car has elected a new Pope?
                            Originally posted by Kai
                            And then dont forget the most important mod for gays.
                            Blow off valve - 300
                              eheheheh
                              well anyway 3rd of June has come and gone, i was away on Business so the car was not taken in. im back in town tomorrow afternoon - thank goodness i made a standby booking at another dealer, will be going in on the 5th
                              and if i miss that 1 i have another booking on the 9th elsewherw
                              im going paranoid!!!!
                              will let ya'll know cross finger 4me
