Hey Guys,
Thought I'd chuck up some photos from my FMIC grill build. I'm doing the same thing as Chris in the UK, and before you accuse me of being a copy cat I had the idea for the look before seeing his
He just inspired me!!!
Its a bit of a pain in the ass of a job, and I recommend getting a second grill to do it on unless you're a professional.
Rather than fiberglassing like Chris did, I used a plastic filler/glue combination known as Q-Bond. Its serious stuff and works wonderfully.
Stages 1 and 2; Q-Bond and Removal of excess plastic
If anyone is wondering, this is the process I am using:
1 QBOND
1) Clean and Dry
2) Roughen Areas to be filled
3) Cut filling sections from spare plastic
4) Apply powder to area to be filled, drip Q Bond on
5) Place filling section on top, apply additional powder and Q bond
2 GRINDING
1) Grind excess plastic away
2) Create small valleys in areas requiring bumper fill
3 BUMPER FILL
1) Clean with soapy water
2) Roughen areas to be filled – 40-80 grit
3) Wipe with paint thinner and allow to dry
4) While drying, test hardner to filler ratios
5) Mix filler as appropriate, and apply to surface
6) Leave 2 hours to dry, check before proceeding
7) Sand with progressively finer grades till right
4 PREPERATION FOR PRIMER
1) Sand surface with 180 grit sandpaper
2) Wipe with paint thinner and allow to dry
5 PAINT WITH PRIMER
1) Apply 3 coats to surface, allowing 10 minutes in between coats
2) Spray a light guide coat on of another colour
3) Allow to dry for three hours
4) Sand with 800 paper till all of the guide coat has been removed
5) Reprime if necessary
6 PAINT WITH TOP COAT
1) Apply 5 coats to surface, allowing 10 minutes between coats
2) Allow to dry overnight
7 CUT AND POLISH
3) Sand with 1200 paper
4) Cut with cutting compound
5) Polish with polishing compound
And these are the required items:
1) Q-Bond Kit
2) Plastic Bumper Filler
3) Spray On Bumper Prime
4) Acrylic Gloss Black
5) P50 Sand Paper
6) P180 Sand Paper
7) P800 Sand Paper
P1200 Sand Paper
9) Cutting Compound
10) Polishing Compound
11) Polishing Rag
12) Appropriately Sized Sand Paper Block
I'll post more photos when i've done some more
1 QBOND
1) Clean and Dry
2 GRINDING
3 BUMPER FILL
5 PAINT WITH PRIMER
7 CUT AND POLISH
1) Q-Bond Kit
5) P50 Sand Paper
6) P180 Sand Paper
7) P800 Sand Paper
9) Cutting Compound
11) Polishing Rag
