Fender rolling
  • Fender rolling
    hi guys just wondering has anyone here, tryed fender rolling there guards, and if so did it make a big differance to the size of rubber you can fit on your wheels with out scrubbing?
    " I wait I resolution derive pleasure this " latest spammer post
    only the fronts may require work the rears are pre rolled from factory so cant really go any further with them?
      no true, i guess i should have mentioned that i was really only worrying about the fronts.
        Yes I have both and front rear lipped and rolled
          I take it a respray is required after?
            this might be a stupid question but how do you roll the plastics parts of the bumper? or do you just roll the metal and taper it to match the bumpers??
            Originally posted by Preen59
              No respray required fortunately!
              The rears where the easiest and just needed rolling and got about a 25mm extension.
              The fronts were a gamble! Had to take out the screws and roll the metal tabs into the lip. Got about a 20mm increase however the plastic guard does not quite reach the metal anymore but is still stable in its unsupported suspended state and it does not touch the tyre. I will ask a body shop to help with that soon.
              With my next set of tyres I'm am hopefull of running a 235/40R17 without any rubbing issues which I hope will stamp out any wheel spin issues!
                so mate costs? and who in bris did it?
                Originally posted by seangti
                  I found this great mobile guy http://www.guardrolling.com.au/
                  I really can't remember how much it was sorry but it was not expensive. I will have a look through my records when I get home tonight and let you know!
                    thanks mate website says approx 60 bucks a gaurd mmmm interesting
                      On the Polo GTI, the rears are rolled from the factory as has been previously stated... Rolling of the front shouldn't crack the paint, as usually heat is applied to soften it up
                      If you are taking about 'pumping out' of the guards then yes, this will require metal work - cutting, filling and painting
                      '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
                        do you recon 235 rubber will fit under the guard?,........if so this will be a done deal and ill do the same, surely this will help with wheel spin. might get a set of pirelli p zeros under her i think. or those maringonis that everyone is talking about.
                          if just rolled guards let you fit 235s I'll be surprised
                            yeah thats wha i was thinking. has anyone ever put some serious thaught into extending the guards to fit bigger rubber underneath? and does anyone have any idea, how much this would cost?
                              It's a simple case of mathematics not opinion. I currently have 215's on and there is still about 3-4.5cms of room in total of both inner and outer guard and shock clearance. When you go to a 235 tyre you add 2cms of width so it will come down to offset of your rims in the end to get the perfect fit with no scrubbing.
