Lower suspension arm bushes!!
  • Lower suspension arm bushes!!
    Had solid suspension lower arm bushes fit today seat solid rear, poweflex fronts and omg what a difference it has made steering braking and acceleration is all more controlled and responsive!! recommend it to anyone! it has really transformmed the car !
    Can you give us a little more info on these?
    Part #'s and aprox pricing?
      Shane (shaneth) used to stock them. I have them on mine. Great stuff. PM him or search here.
      06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
      06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
        Hmmm,
        i have no imagination of where these would go (think I need to do a mechanical course at tafe).
        So probably a few hundred for the bushes and a few hundred for install?
          you use seat ones for the rear of the arm 6LL407183 £14 for 2! and powerflex ones for the fornt of the arm PFF85-601 £30 for 2 and a guide
          but i would recommend a garage fit these i paid £99 for fitting and £80 for lazer 4 wheel align afterwards but for those up for the challenge its a good guide!
            Are these the Seat rear bushes? http://www.jabbasport.com/store/inde...&ref=6LL407183
            And do you know if these are the Superpro equivilent of the Powerflex front bushes?
            http://www.jabbasport.com/store/inde...w&ref=SPF3311K
              the seat bush link is correct but a vw dealer should be able to get em for you??
              yup thats the fronts too but are a bit expensive?? powerflex cheaper!!
                Thanks mate!
                  I can get these bushes from blighty for 7.5 pound sterling each which works out about $16 ish and im thinking of getting a few of them . You have postage on top of that of course.They are not on the shelf and need to be ordered, . I have a good contact at Seat UK.
                  Jmac
                  Alba European
                    Done and done cheers Jimmy!
                      $16 for the full set (4 of)?
                      Well, if you're offering, I'm in...
                        Jmac
                        The word EACH being the operative word there my friend and you only have 2 on your car. Fronts are already solid mate, some may choose to go to poly.
                        Lets not get mixed up here, when i say fronts , thats the front of the front wishbone, and the solids i have mentioned are the rear of the front wishbone.
                        Hope this makes sense
                        Jmac
                        Alba European
                          Ok, so goes on the front of the front wishbone.... The rear suspension is a torsion beam (can you hear the cogs of my mind trying to make sense of this?)
                          Still sounds like a good bit of fun... Take long to fit?
                            You still havent got it mate. Ok front wishbones/control arms have 2 bushes PER side. Ok lets look at one wishbone say the left hand side, this will have 2 bushes, one bush is already hard rubber but can be replaced with poly, and the other remaining bush is the large one of the 2. This one has 2 kidneys allowing the wishbone to move around abit, this is where you can experience a bit of tramp. Ok this is the bush that gets replaced with the Solid Seat Cupra bush, thus no or should i say less movement.
                            Rear is a solid axle beam and stub axles mate.
                            Hope this helps, i know its easy to answer like you are talking at your toolbox, i apologise if i do that sometimes.
                            Jmac
                            Alba European
                              Just looking at the poly options for the front wishbone bushes and see Superpro have a few options which I can't quite make sence of, can you shed some light on this please Jimmy?
                              http://203.31.191.243/fulcrumCat/
