I've been wanting to post this one for a long time. When i'm driving down hill with the cruise control set, I feel the car braking to maintain the set speed. Is that true? Does it actually break or do I just get that feeling?
Downhill with cruise control
It might be engine braking (or even changing down a gear if it is an auto/DSG). I very much doubt that it is actually applying the wheel brakes (that is a feature that is only just starting to appear in some of the more expensive "trend-setter" cars).2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
Also known as BMW.Originally posted by gregozedobe View PostIt might be engine braking (or even changing down a gear if it is an auto/DSG). I very much doubt that it is actually applying the wheel brakes (that is a feature that is only just starting to appear in some of the more expensive "trend-setter" cars).FOR SALE
"VW GTI" QLD Prestige Plate
Pretty sure mine doesnt, it will add on 15-20km'h thru the burnley tunnel if left alone. i normaly flick it down to 5th or even 4th to save the brakes a bit.currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
Definitely not braking. Cruise control is pretty much just trying to keep the speed of the car from the revs. If it starts to go downhill, it tries to keep the rev the same which you'll notice that slight pulling back. But gravity will eventually take over and there's only so much it can do to keep you at the speed.
If you're in 5th doing 80 down a steep hill, you'll be 20km over the speed limit in no time. However, if you're in 4th, it will hold the speed all the way down.
I do this on the Eastlink tunnel where the limit is 80 and I never have to worry about going over speed.sigpic
Sunroof // ICT Tint // Seats // Steering wheel
from my limited understanding, it tries to control it through the ecu, perhaps with timing or fuel delivery.
Certainly not through braking, only engine braking.
Must say mine does a pretty darn god job of controlling the speed, have never had it creep more than 10km/h on steep downhills - quite reasonable IMO.Track Car: 06 Polo GTI Red Devil mkII
Daily: 2010 VW Jetta Highline
Yeah agreed, the car is definitely trying to slow you down. Not sure it's braking though.Originally posted by gregozedobe View PostIt might be engine braking (or even changing down a gear if it is an auto/DSG). I very much doubt that it is actually applying the wheel brakes (that is a feature that is only just starting to appear in some of the more expensive "trend-setter" cars).
Tell me, what's the difference in price between a set of a brake pads or rotors and a new transmission?Originally posted by steve_tdi View PostPretty sure mine doesnt, it will add on 15-20km'h thru the burnley tunnel if left alone. i normaly flick it down to 5th or even 4th to save the brakes a bit.
aus liebe zum automobil
I think I might have a different opinion to what you seem to be implying ie :Originally posted by FL00DY View PostTell me, what's the difference in price between a set of a brake pads or rotors and a new transmission?
It is cheaper to use only your brakes rather than your engine and gears to help slow you down.
IMHO using engine braking sympathetically is unlikely to prematurely wear out a transmission. It certainly hasn't for any of the 11 vehicles I've had for the last 37 years, and I did keep them most of them for long enough to notice if it was going to be a problem. And I don't recall any of my acquaintences needing to repair (let alone replace a complete) transmission because of engine breaking.
In fact, apart from outright abuse causing damage, the main issue I've seen with transmissions in recent years is people using top gear too much to tow heavy trailers using cars/vans with "weak" top gears (eg Turbo diesel Landcruisers, Bedford vans). Even there, it has been (admittedly expensive) bearing and shaft repairs, not totally new gearboxes.
Even VW's latest u-beaut DSG gearboxes do down shifts to provide engine braking to slow you down, so VW's transmission engineers must be pretty comfortable with the idea.
So some related questions for you :
How many examples of premature wear have you seen on manual transmissions that can definitively be blamed on using engine braking, and what percentage is that (of total worn manual transmissions) you've seen ?
How many of these have required a complete new transmission, rather than replacement/repair of the worn components only ?2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
Isnt this just abit more simple than what every1 is makin out 2 be?
When you lift your foot off the accelerator, dont you lose speed?
Thats all the car is doin in cruise control when its downhill, isnt it???
I dont think braking, electronics etc etc would come into it....T Go
MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
I think evry1 is saying exactly that : that the car is NOT braking, just using the engine to slow downOriginally posted by T Go View PostIsnt this just abit more simple than what every1 is makin out 2 be?
