g60 flywheel and vr6 clutch???
  • g60 flywheel and vr6 clutch???
    Hi from uk-polos! I need some info on uprating my clutch and fly on my 07 polo gti, will a g60 flywhell and vr6 clutch fit or any other nk4 golf kits?? no one in uk has fit anything as yet?!
    chreers chris
    chreers chris
    I have been told by one of our local VW mechanics that a VR6 clutch will fit with some slight modification. Is that the kind of info you're after. This was the mechanic, Bug_racer, drop him a PM.
    aus liebe zum automobil
      It's been done a couple of times over here. I am not aware that the VR6 clutch needs to be modified in any way to make it work.
        Yeah I have done it a few times. G3 TDI solid flywheel or 16v Cupra one.
        VR6 clutch fits straight on.
          Use an new original VW Polo GTI throw out bearing.
          For Sale 2006 VW Polo GTI
          Have a Look
          CUSTOM CODE
          Phase 2
            or since your getting your hands dirty anyway why dont you get a ecs clutch with a light weight flywheel.sure there more expensive but worth it in the long run.
            " I wait I resolution derive pleasure this " latest spammer post
              or i was going to say acs clutch kit but since ur in the u.k go ecs
              Originally posted by seangti
                I just had my ECS clutch with lightweight flywheel put in yesterday...so far so good.
                  Whats the pedel feel like, is it similar to stock???
                    how does it feel? better responce on aceleration?,..........how much did it cost you fitted?
                    sorry to post off topic, though to reinforce my point before if your taking your pogo apart best to do it only once with a stronger longer lasting clutch.well thats what im doing when mine dies anyway.
                      agreed, i just wanted to know if they fit as i dont wanna buy stuff then be stuck with useless parts that dont! will this kit fit then
                      its the mk4 golf git
                        Welcome Chris, good to see you have joined up over here. Hows your rebuild going??? whats the ETA of you having it back......
                        BTW have a look at this thread may be of some help. ECS Clutch Thread
                        Have a Look
                        CUSTOM CODE
                        Phase 2
                          another option i can happily advise on is the following setup.
                          is a 12lb Eurospec Flywheel + vr6 clutch kit but do get genuine throw out bearing.
                          No mods required to get these clutch kits installed.
                          However you will find the clutch to be a little stiff for the first 500 - 800kms while it's bedding in, drive lightly for around 350kms and slow increase to spirited driving. Once bedded. The clutch combo is super super light has approx 450 - 500nm clamping force. So no slipping will occur.
                          And is simply the best setup i have driven in a 1.8t.
                          I have driven 23 Golf gti's with all different kind of clutch kits.
                          Audi S4 (2001) - Imola Yellow
                          Secret Project
                            should be back next friday all things going well!!!
                              awsome , let us know how you go with it.
