Hi,
We all know about our roller coaster dyno results. This has been shown to be due to wastegate opening/shutting etc etc...
I have seen a thread which talks about restricting flow to the N75. Will this device do the trick?
So if this tap is partially closed will the N75 not have the issue of opening the wastegate erratically due to getting air at the wrong times etc..... delay the effect of opening the wastegate..
My question is as follows
1. how much would you restrict the air to the N75? fully, half etc etc
2. Is flow and pressure a different thing? does this contraption make it unsafe?
). I have been told that the stock DV is only good for 9PSI of boost. I don't know how true this is, but testing between the stock, Forge, and another brand DV, I have found that the stock one was bleeding off the boost at about 5000RPM.
