Originally posted by Kai
View Post
Air goes through the system forced by the turbo... when the throttle body closes the turbo is still spinning thus it builds up air pressue behind the closed throttle body which can cause surging or boost spike (I am pretty sure this is what causes the 'flutter' sound) which is no good for the turbo as it slows it down and could possibly stall the wheel altogether... And sort of answers the OP's question!!!! The BOV in effect causes a 'closed loop' system where the same volume of air is circulated to both sides of the turbo, which does not cause a boost spike.
If this is not how a turbo / bov works then please enlighten me rather than throwing in a smart ass remake that solves nothing - If you went to the trouble of writing an essay then post the friggen thing and we might all learn something!!!
Now... at full throttle sometimes I can feel my stock tune car surging (feels like the power goes off then on again very quickly) and like you it happens especially in second gear... This may have something to do with the way the ECU controls the N75 valve and what you are experienceing is the sudden turbo spool then the opening of the wastegate on the turbo as it's modulated by the ECU to control boost pressure. It is PI contol theroy - i've hit 11.2psi and my set point is 11psi so i'll open the wastegate - oppps now pressure is 10.5psi I have opened too much and I'll close it again.. They could have reset your ECU during the service and it may have to 'learn' the control loops over again or the ECU may be experiencing a condition it hasn't seen before and is learning how to correct for it...
As for removing the stock BOV, the VW engineers put it on there for a reason and I am sure they will know better than you what is good for their cars components - why would they waste money fitting it if it wasn't necessary?? Just don't start a "my turbo is f#$%@d and I don't know why" thread
