I went to the track this weekend and got frustrated with some issues that happened.
I think the TIP is collapsing, making impossible to go further than 5500rpm.
The ECU need to be upgraded fast, the engine is not developing all what it is capable of.
But I'm very happy with the suspension, brakes and tire setup. The car is more capable of fast turns now, the new pads are also good and this Dunlop I'm using didn't melt!
Yeah matey im keen to hear whats going on with the ECU as well as the Turb. Its a bit of a unit now
Jmac
Alba European
I think he means that the current setup he has now is much better than the K04 setup he previously had, maybe because the turbo he has now is bigger which would provide more torque over 5000rpm?
Here we go with the new evolutions and at least I went to the dyno!
New rear axle bushings, all made in polyurethane.
New turbo WG, now boosting 1,4bar. The old one was too soft, it only holds 0,9bar.
At the dyno the engine develops 360HP and at wheels 330HP... but I don't know...
I believe the engine have a solid 320HP or less… in theory the 42lb/h injectors should feed something near that.
I know with 1,7bar of boost the injectors are at their limit, the air/fuel meter start to fluctuate at full throttle.
The new exhaust manifold and turbo give more torque to the engine when it still N/A. Put the car in movement is easier, I’m very happy with that. I have more turbo lag, but nothing to worry about.
