It's well established that a restriction in the Polo GTI's exhaust system is the down pipe. However, some have managed to convince themselves (and others) that the remaining stock system isn't restrictive. I've taken some shots inside the stock muffler to illustrate how restrictive it is. ...and while it might give off a nice note (cheers Sam
), it's no high-performance muffler.
The first chamber is very restrictive, the only straight-through section is the centre hole you see (less than 1cm in diameter). Most of the exhaust flow goes through the most restrictive second chamber (see grey/heat marks in side shot), then has to turn again into a third chamber before being directed into twin pipes that travel the remaining length along the muffler. Fairly obvious that it's not free-flowing. ...so remember
"don't believe the hype"
