indeed yep just looked at one of the boxes so dont chase that buddy.
polo not starting after clutch change
WAIT. are you a million percent sure the starter motor's pinion sits right into the driven gear of the flywheel? (The teeth are lined up, peek hole to double check.) They should be two gears meshed together. If you have a gap, would make sense. But from the initial diagnostic that the starter doesn't even turn over under load(when it's meshed with the flywheel) might be that it's buggered, try buy another and check if that is the problem.
On the other side of the engine at the bottom, you have your crank. Put a socket on that and test if the flywheel spins from the rubber peek hole(I think Sam suggested this earlier). if you have the wheels up, try put it into gear and check if everything spins by turning the crank(WILL BE TOUGH) Or take it out of gear and spin the wheels by hand.
If it's not mechanical, it's electrical and the boys have suggested pretty much everything there is..
Hope this might give you another idea or two
ECS? There is meant to be a clearance tool with the kit that is used to find lumps on the flywheel housing that need to be ground away.Originally posted by ltwolf View PostMy father thinks it might be because I went from the stock dmf to a single mass flywheel. Would that be my issue
Time to try turning the crank...
The starter pushes the pressure plate through this. It isn’t a full lock up, hits enough to make a lot of bad noises.Originally posted by simon k View PostECS? There is meant to be a clearance tool with the kit that is used to find lumps on the flywheel housing that need to be ground away.
If you can turn it over by hand it’s not the pressure plate fouling, especially if you used an OE spec pressure plate. It’s only the aftermarket pressure plates that foul
Yes clearance tool is handy. But you can see clearly what needs to be shaved down.
I haven’t bothered to read the thread cause clutch change and then no start would tend to mean you’ve not connected all the wires correctly.
Starter ground for example gets left off often.
The starter will mesh when it’s kicked out from its resting position. The starter gear does not contact the flywheel in any circumstance other than ‘start’ on the ignition barrel.Originally posted by JTop View PostWAIT. are you a million percent sure the starter motor's pinion sits right into the driven gear of the flywheel?
Yes Hayden:
If there was a sizable gap or something funky going on, you never really knowOriginally posted by JTop View PostIf you have a gap, would make sense. But from the initial diagnostic that the starter doesn't even turn over under load(when it's meshed with the flywheel) might be that it's buggered, try buy another and check if that is the problem.
What else to cover until the entire crank is turned; we're all guessing
Will the engine turn with a socket on the crank bolt? Of you have fitted a single mass flywheel. There is a possibility that the ring gear is jammed in the bell housing. Preventing the starter turning.
