Update
Been quite busy with work and the car!
Started working last Thursday evening until the AM's, then continued on Friday and got the turbo out, so all the basics to get to that stage, also stripped the front end of the car to be able to redo everything as well as wiring for the fuse holder, placing it behind the battery so it doesn't sit in no mans land.
Frankenturbo K04 in the car on Saturday and with my tired ass luck managed to break an exhaust bolt by double tightening the same nut even though I thought I moved to the next one :| anyway, whoever worked on the car previously, managed to break another stud and I didn't realise that there was a piece left in the engine until Wednesday when I was putting the exhaust manifold back in... No intention to pull the engine forward to replace it? Have one stud spare because I thought it was just missing so got the two. If there is a good reason to dismantle practically everything again for it, then I'll consider it. Let me know!
Ported Exhaust Manifold done, courtesy of Gavin, Thank You!!!!
Sunday had a rest from the car, went climbing instead, Monday had work until 3pm, then dropped past Repco for a few things. Then Imparts ordered 3 gasket sets, exhaust, turbo and rocker cover(for the other polo, leaky half moon), they were missing the exhaust one so my annoying friends at VW Brighton took two days to get that to me which was annoying, would have continued Tuesday evening, ended up going to my climbing gym instead.
Wednesday evening hit up the car, until 3am, got as much as I could done, so Exhaust manifold in, all pipes (TIP was a pain to fit but managed to do it), fittings and accessories, relocated cables and fixed up the mess in front of the battery. Think it was Monday when I sat and redone all the engine side plugs and cable management. 550cc injectors also went in. Got those all rerun and connected up, except the coilpacks
Continued Thursday(yesterday), all day since around midday, connected remainder, organised and tidied everything up, fitted all TIP accessories, got the intake on and then made up the last few vacuum lines as well as the catch can setup. Got all the little things on and finalised, there is so many bits my OCD made me fix it's not funny.
Started putting on the front end, so radiator and ac condenser are back on and connected, just have to finalise the inlet piping to make sure I'm not losing boost over time which it seemed like on the K03.
All that's left is to put on the front end, headlights are getting PPF just because. so waiting on those before finishing with the bumper. Then have the front coilovers as well as the big brakes to put onto the front, then bleed and new fluids for everything! Oil, Trans, Coolant, Brake (rebleed clutch, want it a bit stiffer than it already is), that's it until next week!
Have a rear bracing coming from QLD, have to chop it up to fit the polo as they don't make them for it. Did a bit of a group purchase for them and will have one spare, someone pulled out
If anyone needs, PM me, will do a post about it once it's all done!
Once I get it to work on mine, I fit my watermeth kit onto it then modify the remainder before I take all to get powdercoated. Need one of my Ultra Racing braces to be redone too because it started rusting, whole lot is happening.
Fuel pump should arrive too after 2 months... Hopefully the car can get a base tune before I baby it to the dyno.
Question!
WM, injector after the throttle body, which direction should it be situated? I've put it in from bottom facing upwards, have asked Chris who owned the kit before and he said he had it on the side. Opinions would be appreciated!
Question!
