Rear end sway bar for polo
  • Rear end sway bar for polo
    Does the whiteline polo gti sway bar fit a TDi? And would teflon be suitable for bushes?
    BMW E36 M3 3.0L LTW - SZYBKI
    VW Up! 1.0L - WGN WERKS
    don't quote me on this but I think all 9N series Polos have exactly the same major suspension components (especially big parts like the rear torsion beam) and the only differences is in the specs of the shocks and spring rates/ride height etc.
    So yes if you have a 9N it would fit.
    Make sure those guys deliver the right parts though, Whiteline gave me the wrong end links but were quick to apologise and send out the correct parts.
    Can't help you on teflon, the only thing teflon that I have is a frying pan and the bullets I use while on a job...
      yeah i just sent off a email requesting sum measurements on the whiteline product and check it to the polo. im just trying to think of the name of the plastic used on bushes normally....
      thanks for your help
        FWIW I only know of rubber bushes - the performance stuff is usually polyurethane which is what whiteline includes in the kit.
          anyone know where I could pick up a rear sway for my GTI today in Melbourne?
          Originally posted by Preen59
            I'm waiting for info about H&R sway bars for Polos (got to be better the WL ) ..hopefully I can get a set for mine and will let everyone know what they're like.
              H&R aren't adjustable though are they? at least the ones I've seen haven't been
                eager beaver!!!!!!!!!
                  Yeah and fellas make sure you periodically rubber grease the bushes, ive had a couple come through that have serious rear end creaks as they were dry. Rubber grease and all sweet. I would probably do this 3 monthly.
                  Jmac
                  Alba European
                    Any REPCO dealer I dare say. I got mine through Repco for $200. They just order it in.
                      Finally installed the RSB last night and the difference is very noticeable - same corners the front seems to bite harder and I must have carried more speed into the corners as there were more tyre chirps from the front and I've noticed the ESP light flickering more often.
                      Is overtightening the U-bolts (still by hand) going to be an issue? The bushes look a bit squashed.
                      Greasing every 3amonths is going to be a pain in the proverbial though if it means putting the car up on a ramp and undoing the clamps....
                        yeah I know I can order it was hoping to walk in and buy off the shelf... no matter will just have to order it.
                          Really only need to grease them when they start to make noise (could be 6-months or more).
                          Dave
                            Dave
                            Yeah Dave i might have been a bit on the anal side there, but last 2 ive looked at have been bone dry and sounded like an old bed spring , so like you say Dave hear that bed spring noise that is time. I was just suggesting some preventative maintenance, so i agree with your 6 months mate
                            CHeers
                            Jmac
                            Alba European
                              I got mine through AutoONe for $225
