FMIC & Suspension Upgrade Suggestions/Ideas
  • #46
    Alright, after a bit of finagling, managed to pull the flanges off
    They are definitely sized 108mm
    Driveshafts are 100mm, so the bolts don't fit through because they are off by a small amount from that extra 8mm
    I'll get new flanges tomorrow
    Manual says that the HWY gearbox was produced 05-06, which is weird if they're in 07-08's
    Cheers Sam
    • #47
      so just to get it straight your Polo has an HWY with 108mm flanges. The 100's are spares are they. Polo's got some parts bin treatment I think which is why they'd have gotten older bits trickiling into them. There are lots of HWY's getting around in them though, they are not uncommon. My other box is a JDB I think with some super minor differences and tgere's one other in the 9N3 Gti I think.
      • #48
        Alrighty so after a month fiddling with a rebuild project, it'll be officially done this Wednesday.
        Driveshafts were 100mm and I had 108mm flanges on the trans, swapped them out and have bolted that all back together. Never thought about this before so it caught me off completely.
        Biggest problem encountered was the broken shifter cable, was fun driving the car only in second gear because it unsheathed itself and it was impossible to swap into any others. Got it to the exhaust shop to weld a bracket on and the exhaust together. Would have done myself but it wasn't worth renting a bottle of argon to only do two small welds
        Then got it the Polo Whisperer, Gavin, to get rid of the airbag light, which was unusual because my OBD11 scanner couldn't access any modules, was completely locked out and the engine was running super rich. Stage 2 APR be doing it
        Poor 2nd gear (
        Went for a roadworthy on Friday and they wanted me to change the lower rear bushings because they had small tears in them... I have a receipt showing they were replaced 60k kms ago... Hence why I didn't bother checking them ahahahahahaha... Oh well...
        Machine the front rotors and replace pads
        They complained my rear seatbelt didn't retract at all
        They just got it stuck between the headrest and the seat, I lifted that now so they can't fail it again 😂
        And I never checked the washer system, and I did 5 mins before the Roady ahaha, motor was just blown so replaced that
        Whilst in the efforts of having the front bumper off the car, I thought I might start planning the intercooler for the other car. Only a downpipe is left and the car can run stage 2 comfortably.
        So organised the reverse S3 intake manifold from Sambb <3 should come soon
        Max intercooler size that can fit in the space be 500x300x76, there are better options in 450
        My main enquiry being
        What brand/type of intercooler should I get for the best outcome? I do want one in black though so it doesn't stand out.
        Then, should I upgrade my existing 'turbo to intercooler' line to 3"? Or just 2.5"
        Sadly enough when I did the test I couldn't get 3" silicone through from the power steering/washer bottle to out the front of the battery because the headlight clip and battery bottom being in the way. Any ideas? Run 2.5" the entire route? More I think about it, that might be the best option.
        Then relocating the MAF? sensor that's on the stock intercooler, does it have to be extended and travel across the car to the passenger side? Or should a provision be made for it to fit in on the driver side?
        Any input would be appreciated
        Cheers )
        • #49
          I think 3 inch is pretty big. I think at any powers that are going to far exceed the capabilities of a FWD chassis, that 2.5in is going to be plenty enough and like you say you're going to run into packaging constraints pretty quickly anything bigger than that. A battery relocation to the boot or just changing to a physically smaller battery mounted towards the back of the factory battery tray will allow you to get the pipe work up though there.
          The MAF sensor is post airfilter and will stay that way ie upstream of any pipes that introduce air back into the TIP. The MAP sensor on our Bosch ECU'd car goes pre throttle body and if you switch to a passenger side entry inlet manifold then the MAP sensor will have to go over to that side too, post intercooler/pre throttle body. If you go aftermarket plug n play ECU like a Link or Haltech then you would most likely go mafless and would have to change over to their MAP sensor meaning you would be monitoring plenum pressure ie post throttle butterfly.
          As for IC design look up the "Welly" cooler. Popular in the UK as a single pass IC for VAG transverse cars but not sure if it was ever fitted to Polo's without some massaging needed. You have the choice between bar and plate or tube and fin coolers. Tube and fin are lighter with less thermal mass meaning they shed heat very well with good airflow but will heatsoak quickly without it - not much thermal inertia. An example is my SEAT sport IC which will let inlet air temps hit nearly 70 degrees in traffic pretty scarily quickly, but will shed that heat back out quickly once you get moving. Even with an IC external water spray and having a manual override on both radiator fans, I can sit in a hillclimb start queue and watch the inlet air temps just climb and climb. I dont think a bar n plate would let temps rise as rapidly. Bar n Plate are built heavier inherently and have higher thermal mass/ thermal inertia so can 'absorb' a certain amount of soaked heat before passing it on to the inlet air. Theyll be less prone to heatsoak in low flow situations eg street/drag/hillclimb but maybe not as efficient as a tube n fin when howling around a track with sustained airflow sailing through the core. Depends what you want to use the car for really.
          • #50
            2.5 inch pipework is plenty for the k03s or even a hybrid. Mine are still stock diameter
            • #51
              Alright light delay on everything
              Bushings should arrive tomorrow morning after getting expressed shipped this afternoon so I can get the car rolling again, frustrating that it took a week and a half :|
              Managed to pickup the S3 intake that Sam sent me this morning, Aus Post didn't even bother delivering it on Friday nobody rang the doorbell or even opened the gate to drop it off... oh well...
              Spent all day cleaning the KW V1's, prepped them for sale. Will be running Bilsteins B12's as soon as the car is registered
              Also popped everything else that's lying around for sale too
              Sat down to do the intercooler layout, and the cheapest option is to keep stock 2", already have all the 90* elbows because I have 2 spare intercoolers laying around, just need to find a Z shape silicone tube to fit out the front of the battery (or cut the stock one, because that actually fits too) and an expansion coupler from 2" to 2.5" to fit the throttle body.
              Cabling will be fairly simple, can easily extend the MAP sensor to the other side of the car, what spacing should it run in the pipe though (if anyone knows)? I'll create a nipple in the pipe and weld a bracket or something on so it fits up as close to spec as possible.
              Only other *two* things are the crankcase breather hose that connects to the manifold, do I extend and expand it to fit? what material will suit and not degrade? *and I just remembered and forgot to check how the throttle body tubing runs, would also need to extend this?*
              I'll just buy 1m of 2" Aluminium tubing and cut to what I need
              Just to find a 2.25" outlet intercooler to suit... 620mm max length, 50mm max width on left side then. why can't this be straight forward... dam you Volkswagen
              450x170x65mm Universal Aluminum Turbo Intercooler 2.2&apos;&apos; inlet/outlet Bar & Plate | eBay
              Also not sure if I should get rid of all the vacuum lines and just run one from the manifold to the BOV, Gavin I seen yours
              or run it how Jack had it, which was kinda silly, have a photo of it on my phone will post later
              Cheers <3
              Last edited by JTop; 16-12-2019, 10:15 PM. Reason: *looked at some intercoolers and went to remeasure the spacing
              • #52
                Heyo,
                Long time since I've had time to sit down and post
                Got my car registered early January, and have already started modding it back to what it used to be.
                So the car I initially was working on and trying to get to stage 2, I'm done with. It's now my brothers and every time I need to do anything to it, he has to do it and learn. He said he wants to eventually get to Stage 2, but right now he doesn't care too much, it's fast enough for him.
                My Car:
                Gavin's old 3" exhaust is on (really needed it because the car didn't like the 2" to 1.5" thing I made for the roady)
                Boost gauge back in
                Rear sway bar is on
                Husslas are back on it
                PD160, pod in the stock airbox and upgraded the turbo inlet tube too
                SAI delete
                BOV upgrade, but not venting to atmosphere
                Audi S3/TT Intercooler is being installed currently and here is my progress and dilemma
                about the only solution I can think could work (using 2.5" not what I done, this was just an idea), need to trim the plastic shroud that goes into the radiator support. Will be finicky but oh well. open to other suggestions
                Completed all the easy wiring relocation, stripped back the harness and re-taped it all with black electrical tape.
                Redone my vacuum lines too, swapped out back to the 4 bar fuel pressure regulator
                Need to still extend the pcv line to other side of manifold, so too the throttle body line and a U shape to fit onto the middle thingyClick image for larger version
ID:	1851173Click image for larger version
ID:	1851168Click image for larger version
                Need to still extend the MAP sensor cable. Need to get a mount for it too and fit that somewhere onto the passenger side before extending this cable.
                Started on the plumbing. Sort of sorted out drivers side, passenger side is missing a few bits, only in front of the battery. Managed to sort out the first section from the intercooler.
ID:	1851169Click image for larger version
ID:	1851171Click image for larger version
                Left To do:
                Bilsteins when they arrive, paired with the k1 springs
                Heated seat loom so the leather seats I put in can function
                Find the TT mesh that fits over the bracket that sits under the manifold.
                any comments/ideas would be appreciated
                Thanks )
                • #53
                  after playing with the setup, finally have it "finished"
                  Map sensor in at the top intake, didn't update the photo
                  Just need to make a top cover so the hot air doesn't get sucked in as easily as the pd160's joiner can't be used due to crossover
                  Have left just to fix the boost leak on the line, there is a spot where it just lets the air out making a weird whistling noise, but for the moment I'll be driving it around.
                  what I've got/gotten:
                  Bilsteins are arriving in a month and a half, due to backorder... Sucks but oh well
                  I've got rear TT brakes and hopefully soon, fronts too. go in when bilsteins arrive
                  Catch can setup, have to get a few more bits for it, but that will be in soon.
                  Got my short shifter last night from a friend, so that will go in tonight
                  what's left:
                  fixing up my front bumper, done most the work, just have a few tabs left and a hole to patch and then got to get it resprayed
                  leather drivers seat, heated seat loom from germany (simple install)
                  I can't be bothered buying coilpack brackets, so I'll be making some for myself and for others because why not. I have a set of 034 ones that I'll just use as a template. already have the coilpacks, so they'll sit for a week or two until I get around to this.
                  All I need left is bracing then. Rest of the car is done for the moment
                  I'll do stage 3 in a bit, not super keen on the power just yet.
                  • #54
                    Jesus it's been nearly two months
                    How is the car going? Pretty good actually, the list of mods to be done is shortening and I'm getting excited
                    What I've gotten done:
                    Fixed the front bumper, got that hole patched and dropped it off to a shop to respray. Legit looks like new and there is quite literally no difference to the front fenders.
                    Fixed my boost pipe issue, when replacing the bumper. just needed more hose clamps and that's sorted. kept splitting with anything more than 15psi of boost due to ****ty vw clamps not holding, but also the engine twisting with load. Holds up the 20psi quite nicely
                    Leather front seat. FOUND ONE
                    Got that into the car, I have a full CLOTH interior set of seats and door cards if anyone needs + hardware, $350 if anyone is interested, only selling the full set because parting out I'll end up with an odd set
                    Dash cam is in, nearly got the rear one done but then I managed to get the end of the cable jammed and lost its head so...
                    Fixed my bluetooth too:
                    SO had to replace radio because Korean made was rooted, yes I scanned it and it came up with code 014 defective
                    Luckily I had a spare one sitting, went onto vwcodes dot org, payed $22 to unlock the radio, and discovered I needed a new bluetooth module because this one I got from the wreckers was caked... , there goes another $104. BUT I HAVE BLUETOOTH NOW SO
                    All I can think of right now. Probably did something else but I've easily forgotten
                    *SHORT SHIFTER AND SOLID BUSHINGS , also did a thing to get air into my PD160 because criss cross apple sauce
                    **Fixed my low pitch horn by replacing with a Jetta horn, same weight and everything so yeah...
                    ***fuse blew for rear tail lights, replaced and replaced the blown bulb causing it
                    What to do and what's coming:
                    Got to go Supernova, get the full LED bulb set because yes
                    Need to get a set of coilpack spacers, I have the R8 coilpacks but quality non plastic ****ty spacers are non existent unless you get them from another country for >$150 I have a set of 034, so i'll try fab something up from those as templates
                    Heated seating loom. I have the buttons and the seats. SO just waiting for the loom to come from europe right now which is quite the problem
                    Just like my bilsteins which I've been waiting for, for the past 2 months. Waiting to hear from the UK company if they're going to dispatch or not. If not I'll end up picking the H&R's that my mate has
                    If they do come, got the KW springs to match them up with, so that'll be an interesting experiment whether the fronts will fit.
                    Waiting on another mate to part out his stage 3 parts, already called dibs on things so quite happy there:
                    Got front TT brakes coming, have the rears already, need to make the spacers for the carriers so they can fit
                    Have a catch can yet to install, going to do it with another gti friend who's already done his. but corona so
                    Got a special hybrid turbo coming
                    550cc injectors too
                    got to buy a highpressure fuel pump and also to fix my fuel level sender, because 1/4 tank and this b*tch empty
                    AND FINALLY, the full set of Ultra Racing strut braces.
                    PPF headlights, and get a good clean and polish of the car
                    Only for events will I ever put on my carbon mirror covers, because they special
                    And that's it really
                    other than my want and need for cup kit body kit, a decent spoiler to slap on the back and make some custom ass tail lights
                    but that can be done when I fin uni and get a full time job, also with a full forged engine rebuild because well, why not
                    probably missed a few things, but I want this car done whether the world ends or not
                    peace out, stay quarantined and have fun in boring times
                    • #55
                      If you don't have any joy with the UK supply of the Bilsteins just let me know the part numbers and I should be able to get them direct from Bilstein and quote a price delivered. I do seafreight shipments (cheaper) once a month and airfreight (more expensive) every 2 weeks, so the only delay will be if Bilstein Germany don't have stock.
                      Gary
                      Golf Mk7.5 R, Volvo S60 Polestar, Skyline R32GTST
