hi guys just installed the Forge Splitter BOV/DV onto my car. its a 07 polo gti. THe only mods ive done are a seat intake and panel filter. im not getting much noise from this valve. is this normal? has anybody on here have this set up on a similar car like mine. With adjustability how many turns should i turn it clockwise for it to be right?
Splitter BOV/DV
I have the same set up, and it is normal. You have to remember that you are only running very low boost as standard(7 PSI), this will not produce too much noise when you change gears or back off the throttle. If and when you get an ECU tune, you will get more noise as you will be running higher boost(about 15 PSI).
