Hey,
I am after a bit of advice and wondering if anyone has had a similar experience. My polo is growing old and has hit the 175k km milestone. The OE clutch is still installed and when I go to engage the clutch upshifting (or from a standing start) I get a clunking noise around the lower middle section between the foot wells. This only happens when I attempt to release the clutch pedal a bit too 'fast', if I release slowly and very gently there is no clunk.
It also only happens when accelerating, as I can aggressively let the clutch out deaccelerating with no noise. I have read other posts and some have suggested it is the clutch/flywheel? I have crawled under the car and checked all the engine mounts and control arm bushes and they seem fine. I also have a grinding noise when revving out first gear which I suspect sounds like a buggered throw out bearing.
If it turns out to be my clutch/flywheel are there any recommendations? I am looking at the BFI stg 2 from ECS. My mods and info related to my suspension set up are detailed in a previous post (BamaQLDs its getting there). Haven't contributed to the post for a while as my ass has been broke... keen to keep the polo alive.
Thanks in advance..
Thanks in advance..
