Electrical Issues?
  • Electrical Issues?
    Hope someone can help me
    Over the last week, my car has almost stalled and the power steering has cut out (and the light came up on the dash).
    The first 2 times it happened when reversing up a hill and the revs dropped really low (I was trying to drive quietly). But... today it happened while waiting at lights with the clutch in. Idle speed dropped to about 600 or less and all the interior lights went off for a second then it came back to normal (bout 750revs) and the power steering light was on (and I could hardly move the steering wheel).
    Has anyone else had this problem or know what might be causing it to happen?
    It's never happened before last weekend and now it's happened 3 times (and I'm at idle A LOT in traffic).
    this is a TOTAL shot in the dark, seeing as im a f....ng kook with cars and whatnot, but..........
    similar symptoms with my ole' discovery..... faulty fuel pump/gauge.....
    those of you who will, may certainly laugh- i told you i am clueless. just going on past experience.
      Mine did this with a BOV!
      it nearly goes into limp mode.
      Edit: Im talking about the idle.
        Hey Tosspot what your car? I have a mk5 TSi and it lost all power under load the other day on the way to work been fine ever since
        Chris aka TSi2NV.
        MK6 Golf 90TSi.
        MODS: 20% tints, H&R Lowering Springs (45mm), 18" rims
          2007 Polo GTI
            Have you checked the battery terminals? They can come loose and may cause it.
              You need to run a scan mate , could be anything there, if you have had lights im sure you will have codes
              Jmac
              Alba European
                every time i'm waiting at the lights my revs drop to about 600 and then push back up to about 800-850, then settle back to 700. my interior lights never turn off however, thats weird mate, especially seeing as your power steering packs it in. take it in to VW and get them to deal with it. theres no doubt that would be covered.
                new car please?
                EDIT: sam, its because you chose that rubbish colour . i have it just on my bonnet and look what happens to me!
                  Had this same problem on a 2004 VRX Lancer and could never find out what it was... replaced O2 sensors, knock sensors, coils packs etc etc... In the end just sold the car
                  '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
                    Happnes to mine a few time 2...
                    Clutch fully in and it just stall itself at stationary....
                    Also that gear crunching is annoying..
                    And the nosie it makes will broke my heart...
                    will wait till 7500km and back to dealer for service + check up...
                      Friend of mine has asked me to look into this, as they are having identical issues with their polo. The dealer has tried replacing battery, alternator etc. And their warranty has just expired, and the problem has come back again.
                      Anyone had this fixed? got any tips on what might be causing it?
                        Not that it will make you feel any better.... but if it is electrical it is a long hard road. I know with Mk3's if they start cutting out it is the coil or the relay. Given the steering light comes on, I'd be checking relays.
                        Just work back from the steering.
                        1. Steering motor is okay?
                        2. Alternator to power the motor okay?
                        3. Battery alright?
                        4. Relays swapped out
                        5. ECU
                        But it sounds like a regulator on the alternator, maybe it chucks on full load, hence revs drop and then spits the dummy and instantly no power for the steering rack? Just a theory...
                        Originally posted by Kai
                        And then dont forget the most important mod for gays.
                        Blow off valve - 300
                          Guys this one was resolved, batch of bad fuel did the trick!!!!
                          Jmac
                          Alba European
                            Jmac
                            Very interesting. Any idea how the fuel would impact on the power steering? Did the bad fuel send it into limp mode?
                              Vehicle cut out mate, this caused power steer loss. Bad batch of fuel , vehicle would intermittantly cut out, filled with fresh gear and fixed. Suprised me too. No credit being taken here VWGTI found out for himself after filling with fresh juice.
                              Jmac
                              Alba European
