Nice info there! I have heard the trick with the tissue in the past, but didn't remember the exact process. I will try it on the stock exhaust manifold I have just for fun.
Also after reading some threads on greek forums, a 4-1 type manifold is better suited to my project as I'm looking for top end power. Fortunately my exhaust fabricator is very good, he has made full custom systems for numerous powerful turbo and N/A cars. He knows his stuff, so he can help me.
55mm exhaust pipe is apparently a little bigger than needed, so I may go with a 52mm one.
As for cams I lean towards dbilas. They have been used with success in similar setups and maybe I can find some used ones with low mileage. Reprofiled cams are hit and miss, I don't want to risk it.
The stock compression ratio of the engine is 11.5:1. Quite high for a 1.6 16v 105hp unit. To compensate for the slight compression loss due to aftermarket cams I may have to skim the head a little bit, or maybe use a thinner head gasket.
Eventually, the engine block I'm going to use will be a 1.6 with AZD code. It is cast iron rather than the stock aluminium one.
