I finally got a chance to test out the new coils over the weekend and I am happy with they way they react with the road. The reason it felt so bad straight after the install is I forgot to torque the wheel bolts
. I torqued every other bolt, got the car off the jack stands went upstairs, cleaned myself up, came down and forgot to do the wheels. Lost my wheel stud lock key in the process but feel lucky that nothing else major happened.
Correct on the lowest setting on the front coilovers when it leaves the factory. I have since had to raise the front so the wheels didn't scrub the guards anymore. Now everything is done up properly and the wheels are aligned there is no more clunking in the rear springs and I am very happy with the outcome. Also set the rear sway bay on the softest setting as I have been told that is the way to go when you get the front sorted. I didn't realise you can remove the collar in the rear springs to lower the rear a bit more but that's a job for another day.
Spent a small fortune getting these black beauties. Might not be the best bang for buck but I am sure I can't go wrong with a lifetime guarantee and I am hoping that they will never need replacing or upgrading. Will be getting them installed shortly but I am feeling a bit lazy doing these myself so might be forking out to pay the 'pros'. Looking at getting Fulcrum suspension in Yeerongpilly to throw them in and align everything.
Bloody roof lining is starting to sag so the DIY didn't go so well. Maybe not enough adhesive, although I did spray both sides. Thinking of just painting it now or removing it all together as it will remove a bit of weight from the top of the car. Could be too hot in QLD though without some insulation on the roof considering my car is black.
. I torqued every other bolt, got the car off the jack stands went upstairs, cleaned myself up, came down and forgot to do the wheels. Lost my wheel stud lock key in the process but feel lucky that nothing else major happened.Correct on the lowest setting on the front coilovers when it leaves the factory. I have since had to raise the front so the wheels didn't scrub the guards anymore. Now everything is done up properly and the wheels are aligned there is no more clunking in the rear springs and I am very happy with the outcome. Also set the rear sway bay on the softest setting as I have been told that is the way to go when you get the front sorted. I didn't realise you can remove the collar in the rear springs to lower the rear a bit more but that's a job for another day.
