I bought a 2008 9N Polo on the weekend. The car seems quite ok through my 20km odd journey home from picking it up so not concerned with that.
The thing which is the quirk with this car is the rear hatch's latch.
The previous owner instructs that to open it requires a counter-clockwise twist of the key then when turned, lift the handle. I've so far managed to get it opened once - immediately after I was given the instruction on it and then trying immediately after it didn't open again.
If I don't follow the directions I will hear the motor to have it unlatch but the hatch stays closed and locked. It's quite weird.
I didn't have enough time to keep fiddling with it to figure it out fully and be ok with the quirk. I'm guessing that there needs to be some sort of "reset" internally to have it open again.
So to the question - can the motor or latching mechanism be changed? If I go to a wrecker to buy the motor and latching unit, can it be swapped so that I can get a more predictable hatch opening expectation? Would the key-fob hatch open button be able to unlock/open the hatch again if the mechanism was changed?
