sai delete question
iv found two oval shaped resistors online (witch are stupidly expensive for what it is) that should fit onto the SAI Sensor and N249 electric system but i cant seem to find a larger oval shaped resistor that would go into the power cable that powers the actual sai pump, its the same oval shape as the others just much bigger or should i just go for the much cheaper chinese 10w 330ohm resistors?
