Polo 6R and 6C coilovers
  • #16
    I agree.
    Sure, if you corner weight the car then adding passengers, luggage etc will affect the corner weighting but if you simply set the car up like most people then a tank of fuel, 4 occupants and some luggage will add 350kg.
    • #17
      Originally posted by Sydneykid View Post
      Seriously, a Polo Gti weighs ~1250 kgs and a sunroof adds around 30 kgs, that's 2.4%. Does anyone really think that adding 2.4% requires different spring and damper rates? What about when you fill it up with fuel, that's 30+ kgs, do you need different coil overs for when it's empty to when it's full? OMG what about when there's an 80 kg passenger, a quick pit stop to fit different coil overs?
      Mathematically, adding 30 kgs in the form of sunroof would add about 2 mm to the preload of the standard springs, allowing for movement and leverage ratios. If someone suggests that means different coil overs (which would have an even high spring rate, therefore less preload) then I strongly suggest you find somewhere else to buy them because they are delusional.
      Gary
      Have a look at the attached. Just for the one model Golf there are 3 avaliable coilovers. The difference between 2 is only 69kg.
      Sent from my SM-G925I using Tapatalk
      • #18
        [ATTACH]18311[/ATTACH]
        That's for a Golf Mk6.
        There are 3 models because of physical differences in the structure of the vehicle.
        50mm strut with FWD
        55mm strut with FWD
        55mm strut with AWD
        To see if there are any differences for weight you need to look at the TUV certification documents and look at the spring rates or calculate the spring rates from the coil specifications.
        What do you mean by "the difference between the 2 is 69kg"??
        • #19
          Hello,
          I am new to this forum and I have been doing some research on coilovers or lowering springs to remove that 4WD look on my stock 2015 Polo 6C GTI.
          I am wondering if you can lend a hand to my enquiry.
          i am not sure if the eibach pro spring kit is going to give me the desired effect and I am wondering if the Eibach coilovers kit would provide a lower stance that just the spring kit.
          Altrnatively what other springs or coilovers would you recommend to get a nice lowered look?
          Chris
          • #20
            P.S I am not looking for a "slammed" look just something to provide a meaner, sleeker look
            • #21
              Budget?
              • #22
                Between $1000-$2000
