So the abs sensor cable, that runs along from the sensor into the car/loom/wherever has come out of its clips on the rear beam and has been rubbing on the inside of the wheel. This has caused major wear to the point of throwing up brake system warning lights and turning of abs.
Question is, can the whole cable be replaced at all, or do I have to just fix where it has worn through? What would be the best method for this?
All help is appreciated.
Cheers, Ben
Cheers, Ben
