I had mine lowered by a mechanic. He chose not to remove the plastic cowel. He cut 40mm holes (using a hole saw) directly above the strut top mounts to lower a special tube socket (Like a "C"shape) onto the strut top nut. A 7mm allan key can than be inserted underneath the plastic cowel into the strut rod. He used 45mm rubber blanking gromets to cover these holes over when finished. Looks OK.
The reason I asked for your advice is that I will need to do the job again and this time on my own. Hence, any other "tricks" which may make the job simpler and safer are most welcome.
I had made a mistake in ignoring other POLO owners experiences with just changing springs and not the shockers. There is an awful deficiency in rebound control as the H&R 35/55 springs (930kg) are so firm.
The rear has now been tamed by installing KONI adjustable sport shocks. Now for the dreaded job of replacing the the front with KONI adjustable strut towers. I am keeping the H&R springs as they lower the car nicely without any tyre rubbing issues on 18x7.5 rims. (215/35 tyres)
Kind regards
VEEEUU
