What tire pressure?
  • #31
    Originally posted by MrDeathLad View Post
    i always thought it was the tyre compound that made a differnce to resistance not tyre pressure. sure, pressure makes a difference to the contact surface area but a softer compound = more resistance/grip = more fuel consumption? please correct if i'm wrong
    Tyre compounds do play a part given that wheels rarely track dead true all the time. So where scrub is significant, a compound that allows the tyre to slide will reduce "rolling" resistance. Tyre pressures play a much greater part than compounds because when you look at it, an underinflated tyre had a greater contact patch and a smaller radius at the contact patch than the rest of the tyre, and so has to climb all the time. It is a bit like driving on an oval wheel. Now you have to overcome the vertical load on the tyre.
    After all this, you do have to be very careful varying tyre pressures as the tyre sidewall plays a major role in a vehicle's suspension. The Holden Radial Tuned Suspension was not just marketing hype. If the tyre sidewall is stiffened and the rest of the suspension components are unchanged, you can end up with quite a degraded suspension system with steering affected and tyres bouncing and losing contact with the road.
    At the moment, one of the reasons why the F1 teams do not want to go with 18" rims (as opposed to the 13" rims they currently use) is because the designers are going to have to make significant changes to the suspension components given that the tyres (sidewalls in particular) play such a large part in the suspension.
    • #32
      For tyres with stiffer walls like AD08, Dunlop ZII, etc, I lower the PSI by 2-3 PSI from factory specs.
      • #33
        I should also say that a flexing sidewall or tread absorbs energy. Rubber has different characteristics on compression and then rebound. This is seen as heat, and this energy is absorbed from the car and so an increase in rolling resistance.
        So, you don't want to under inflate your tyres as this can cause them to overheat, but you also do not want to over inflate them either as this can cause them to be too stiff and then end up with suspension issues.
        • #34
          Rolling resistance is mainly energy loss through internal friction of the tyre itself. An increase in inflation pressure will go some way in reducing RR, but that effect tends to decrease exponentially as you add more air. The choice of tyre (and how it's designed and constructed) will have a bigger effect on RR more than anything.
          It is possible to create a tyre with high wet grip and low rolling resistance, at the expense of wear. Continental usually apply this design philosophy to their tyres, for instance.
          • #35
            Sorry to revive this but it's obviously very very important we get tyre pressures right.
            This is the label inside my fuel cap:
            Looking at the label I'm assuming the the kPa are front (220 = 32 psi) and rear (200 = 29 psi) carrying two people.
            My new rims are 18" diameter and 8" width running Kumho ECSTA SPT 225/40ZR18 92 Y XL, do those same pressures sound appropriate for these tyres?
            • #36
              No chance, lower profile requires more pressure and it really is a stab in the dark when you're going outside of manufacturer specs. I recommend from personal experience at least 38 front and 36 rear.
              • #37
                Thanks Gavs,
                Would I be safe with 40 front and 38 rear?
                • #38
                  yes that is fine (hot pressure that is)
                  • #39
                    Thanks alexz,
                    So if cold a few (2) extra psi?
                    • #40
                      No opposite, 2 less psi. Hot air expands.
                      I have mine at 36psi (250kpa) cold all round and on a nice day (23deg) and a hard run they sit on about 38-40 psi when hot which is where I want it. Any more and it will start to chew the centres out and reduce grip.
                      I found that the recomended 32 is way too low for my 40 profiles (which isn't even that low really) as it was starting to chew the outsides of the tires causing them to feather.
                      • #41
                        This is the Polo section of the forums.
                        The photo you have uploaded looks like it was taken from a Mk5 Golf. You may therefore, get different recommendations than if this were posted in the Golf section.
                        I interpret that as more of a pictogram designated to mean "normal load" (or half load), rather than taking it too literally.
                        Hence, the second row would therefore mean "full load" at 240 kPa front / 290 kPa rear.
                        The widespread use of symbols, icons and pictograms may seem a bit esoteric to those from an English-speaking background, but this sort of thing is common in Continental Europe due to the number of languages and dialects.
                        For the Mk5 Golf, Volkswagen have a tendency to recommend the same inflation pressures for the same model variant, irrespective of tyre size. For instance, the following pressures:
                        1.6 FSI: 200 kPa (29 psi)
                        2.0 FSI: 210 kPa (30 psi)
                        1.4 GT: 230 kPa (33 psi)
                        2.0 GTI: 240 kPa (35 psi)
                        3.2 R32: 280 kPa (41 psi)
                        ... would apply irrespective of the tyre size (or at least, those available as factory options) fitted on the vehicle.
                        The increasing inflation pressures reflect, amongst other things, increasing vehicle weight. On the above list, the 1.6 is the lightest variant, while the R32 is the heaviest variant.
                        Note 1: inflation pressures for vehicles with an automatic transmission may be slightly higher, as weight distribution is pushed forwards (heavier front load, lighter rear load), but this is not always the case and depends on the model variant.
                        Assuming you have a 2.0 FSI automatic (not DSG), it would explain the inflation pressures listed on your fuel flap (220 kPa front / 200 kPa rear). So given the weight of your vehicle, an initial pressure of anywhere between 220 kPa (32 psi) to 240 kPa (35 psi) would be a good place to start, and then adjust to your own preferences. You may go higher than 35 psi if you wish, but never go lower than 32 psi.
                        While higher inflation pressures generally promote slower wear rates, for your particular vehicle, an inflation pressure far in excess of 240 kPa may compromise vehicle dynamics and/or braking distances to a certain extent (depending on vehicle load, as well as the tyre itself) if the tyre's contact patch isn't allowed to sufficiently deform, given your vehicle's weight (or lack thereof).
                        Note 2: unless stated otherwise, the figures listed on the fuel flap always refer to cold pressures (i.e. tyres at ambient temperature). Same goes for the pressures listed in this post.
                        Note 3: irrespective of the contents in this post, always defer to the sticker in the fuel flap (or wherever) for correct inflation pressures in the first instance.
                        • #42
                          Excellent info and thanks to those who've posted.
                          Yes my car is a 2.0 FSI Golf. I was awate this thread is in the Polo section but when I searched the forum this thread seems most relevant, perhaps this should be moved to the wheels/tyres section of the forum.
