Tyre pressure question - 2013 polo gti
  • Tyre pressure question - 2013 polo gti
    Hi guys
    Not sure if anyone has answered -looked but found nothing specific...
    The placard says about 270(rough conversion 39) but it seems high to me...
    What tyre pressure for the polo gti do you guys recommend? 214/40/17 tyre size
    Harry
    MY13.5 Red Polo GTI
    Harry
    MY15 RED Polo GTI 6C - with DA Pack
    VW spend millions of $$ on working out whats' the best pressures for the tyre to car ratio, I would stick with what the fuel cover sticker says personally..I see a lot of over and under inflated tyres and the are ruined. Keep them at the recommended amount and then keep checking them every 5,000km or so if they are wearing on the middle of the tread more then reduce the pressure, if they are wearing more on both outside edges then increase the pressures...VDUB...
    BRISBANE / GOLD COAST
      39 sounds high for stock, but is what I would run my fronts at for optimum life vs handling.
      I tend to run my rears a bit lower as there is less weight to keep them flat on the road, say 36...
        Cool... Thanks... Might give a few setting ago and see how it drives
        Much appreciated.
        Harry
        MY13.5 Red Polo GTI
        Harry
          Originally posted by Harrydhillon View Post
          Hi guys
          Low profile tyres need higher pressures because they have less air in them to provide cushioning. There's less sidewall to cushion you from bumps.
            There's no real reason to deviate from the manufacturer's instructions or specifications unless you wish to alter the car's dynamic behaviour.
              Ok..thanks... Will stick with what's recommended
              However...can anyone delete that comment that's sounds like spam??
              Harry
              MY13.5 Red Polo GTI
              Harry
                Has been reported, a mod will get to it.
                  Thanks.... not sure if I could report such thing and how...
                  Harry
                  MY13.5 Red Polo GTI
                  Harry
                    Harry
                    MY13.5 Red Polo GTI
                    Use the little triangle Bottom left
