Smallest wheels and widest tires to fit Polo GTI 6R
  • Smallest wheels and widest tires to fit Polo GTI 6R
    Hi there,
    What would be the smallest wheel diameter and widest tires I could fit into Polo GTI 6R.
    2012 Polo GTI MY12.5 - Weitec Hicon GT - Whiteline Front Control arm - lower inner rear bushing (caster correction) - Whiteline Rear Sway Bar
    To do: Lightweight wheels - Adj. Front Camber
    You could fit smaller brakes, fit 12"x10" ET10 rims, and some 295/45/12 tyres (assuming they make tyres that size).
    It'd look pretty dope, but likely not be roadworthy
    2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
      16 inch if you're lucky, something like the mk4 golf GTI might fit diameter wise. If you wanted I'm sure you could make a 235 tyre fit easily enough...
        knew you came from Sydney without even looking at the location in your profile
        what size brakes are on the polo 6r?
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          Assuming the OE fitment is 215/40 R17 87V XL tyres on 7.0 J x 17 ET 46 wheels, then...
          255/45 R15 93V tyres on 8.0 J x 15 wheels.
          I think that's the smallest and widest the roadworthiness regulations allow you to go, in regards to permitted tyre and wheel combinations.
          But keep in mind that fitting such a combination on your vehicle may breach other regulations (e.g. tyre & wheel must not protrude beyond the body, etc).
          Front brake disc diameter on a Polo GTI is 288 mm.
            GTI/TDI is 288mm front, TSI is 256mm front (same as the Mk4). So with TSI brakes, you could fit anything that fits a Mk4 Golf
            To the OP - if you're serious, do some research & find a pic of a GTI w/ the style/size/shape rims & tyres you want, and find out what size they are - easier than asking randomly
              Since the 9N3 GTi has the same brake setup as the 6R GTi, you should be able to fit 15" rims since some 9N3 GTi owners have done this. And from memory, Gambit was able to get 15" rims to clear the brakes on his 6R GTi a while back (I don't think he ever ran them, though).
              Good call, Dylan - I've seen less helpful posts (than the one you were referring to) but only just.
              The 1" additional width limit over OEM is a NSW thing. The OP is in Vic so he can get any width rim that will fit within the guards (and has an offset down to 13mm less than the stock rims since the 1" track increase limit is nationwide).
              Resident grumpy old fart
                Okay, assuming no limit to rim width, then:
                285/40 R15 92V on 11.0 J x 15 wheels (or 10.5 J / 10.0 J / 9.5 J).
                But fitting that on a 6R Polo may not be entirely practical.
                  Fitting smaller wheels would be counter productive as it would put the speedo further out than it already is. (Usually 7kph at 100kph)
                  So if you go smaller it will be even worse. Would also lower the gearing so it would rev like crazy a lot earlier Would cut the underbody clearance as well
                  I think the legal limit is 26mm smaller overall diameter in all states.
                  Have a look at this for the effects of different sized wheels
                  Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
                    If he went for smaller rims, then he'd get taller tyres (through a profile and/or width change) to maintain the rolling diameter.
                    Should have added that the offset almost cannot be greater than OE (ie no track decrease). With that and the guards limitation, I think you're safe in assuming that the megawide wheels and tyres would not be practical.
                      Hi all,
                      I am thinking of fitting rota grid 15x8 like this one the link with 225/45 r15 or 225/50r15
                      15x8 Rota Slipstream - Steel Gray(5x100/e40/57.1) Wheeldude.com - Professional wheel dealer.
                      Or if not maybe I could try Andros Spec D, but it's 16x7.5 +35 maybe on 225/45r16 from tirerack.com
                        The diameter of 225/45 R15 87V tyres (583 mm) is too small to be fitted to a Polo GTI.
                        225/50 R15 91V (607 mm) or 225/45 R16 89V tyres (608 mm) are a closer match to the original tyre's diameter anyway.
                        For the benefit of Victorians, here are some selected extracts from VSI 8: Guide to Modifications for Motor Vehicles (October 2011).
                        The width of any replacement rim must not be:
                        1. more than 25 mm greater than the widest wheel specified by the vehicle manufacturer for that model or vehicle series; or
                        2. less than the width of the narrowest rim specified by the vehicle manufacturer for that model or vehicle series.
                        The overall diameter of any replacement rim and tyre must not be:
                        1. more than 15 mm greater than largest diameter tyre specified by the vehicle manufacturer for that model or vehicle series; or
                        2. more than 15 mm less than the smallest diameter tyre specified by the vehicle manufacturer for that model or vehicle series.
                        The wheels and tyres must not foul any part of the body, suspension, steering or brake components at any position of the suspension travel or steering movement, and, when in the straight ahead position, the guard or bodywork of the vehicle must cover the section width of the tyre.
                        Source - Vehicle standards information : VicRoads
                        So for a 6R Polo GTI, these are the limits:
                        Maximum width = 8.0 J = 203.0 mm (7.0 J = 178.0 mm)
                        Minimum width = 6.0 J = 152.5 mm
                        Maximum diameter = 619 mm (215/40 R17 = 604 mm)
                        Minimum diameter = 585 mm (215/45 R16 = 600 mm)
