Check engine light
  • Check engine light
    Hey fellas anyone know what this means? Its on constantly as of this morning.
    2001 S4 Matte Charcoal metallic | M6 | MTM tuned | Zinram 3.5inch catback | SRM SMIC's | ST Coilovers | Work Meister S13p's
    2002 Bora 4Mo Indigo Blue Pearl | FK Coils | Air box swisscheesing | Audi B5 S4 Wheels
    Could be many things. Could be an O2 sensor, throttle body error, acceratitor pedal error, excessive misfiring...hundreds of things, it covers most things excluding most gearbox issues which has a separate warning light.
    If you have VCDS you can easily see which part is playing up.
      Gah, thanks mate.
      Anyone in Sydney, mascot area have VCDS and availible to do a diagnostic sometime today? Would prefer not to take it to the dealership right now with CAI etc on it
        You can call VW assisit (NRMA) and they can tell you the error code. Not sure if they care about mods. Does the car have any strange symptoms?
        My car just went in yesterday for solid engine light, was misfiring cylinder 4.
          Yesterday I noticed a rattle when I left work. Engine was cold and got to about 3000rpm and a sound like something lose occurred but then nothing, had full power once warmed up then this morning engine light is constantly on.
          So I can just call vw assist and nrma will come check it out? Never used it before, whats the process?
            Yes, you call them, they take down your details, and they send out NRMA to have a look.
              Well that was quick. Called and he was here in 15minutes.
              Got an error code, can anyone explain what it is?
              P0556: Performance or range in brake booster pressure sensor circuit.
              Any relation to wheel spacers?
                P0556 - Brake Booster Pressure Sensor Circuit Range/Performance
                Read more: OBD2-OBDII Engine Light Trouble Code P0556 - Brake Booster Pressure Sensor Circuit Range/Performance | Engine-Codes.com
                  Well that's not too serious. Not to say its not bad but it can still be driven. Just means you will have no brake assist or esp because the computer doesn't know how much you are breaking for it to raise the pressure. Because the brake booster runs from the vacuum of the engine you probably won't notice any difference to the braking.
                  Still feel free to fiddle around with the sensor cable which is on the back brake booster (which is a big black disc with the brake fluid reservoir on top) try fiddling with the cable, might have just come loose...
                  You done a 30,000km service recently? I know they flush the brake fluid so maybe they hit something...
                    It has 7500 on the clock, the booster is right down behing the engine yeah? Buggered if I can reach down there to see if anything is loose though
                      Mine did a similar thing but the noise stayed. The code I got was fuel pressure regulator low pressure. They changed the fuel pump but the noise was still there around that area. They have had the car for 2 weeks and still haven't pulled of the rocker cover to check what it is.
                      MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
                      MY12.5 Polo 6R GTI
                        Well drove home, absolutely no loss of power or any strange noises. Brakes felt normal too which is good, I feel a bit safer knowing everything is working.
                        I'll be calling vw to book it in for a fix sometime this week.
                        Is it worth removing my apr tune and cai seeing as its an unrelated problem?
                          Depending on the dealer you should be right with the CAI, but i would be removing the tune and having the factory binary reflashed ASAP. Problem is though mate, if the dealership isn't friendly and wants to screw you, they will instantly know it's your car if they look on teh forum. I can't imagine there are too many stealth grey gti's around with aristos....
