Well I think I am down to the last noise that I have to sort out at the moment (touch wood)... this one is also peculiar.
Okay... in the morning when I set off I 'feel' this intermittent grinding/scraping almost rotational noise for a few kms. It happens from cold, and it also happens to a lesser extent if the car has been sitting for a little while.. For example when I go to the shops for lunch after getting to the office at 8:30.
It goes away after you drive for a a few kms and as I say its intermittent in its duration / occurrence, but will happen every day, if that makes any sense.
I have had a look at the drive shafts, there are no torn boots or leaking grease, thinking that would be the cause. I am yet to check the rear, but I am going to my VW mechanic friend tomorrow to put it on the hoist and see if I can spot anything out of the ordinary.
The part that is throwing me is what could be causing this noise in that it stops after a few kms but comes back every time you get in after its been sitting? I was thinking brakes grabbing but its not the sort of sound you would get from brake pads dragging or similar.
I thought perhaps the lowering of the suspension has damaged something but I had a look at the fronts last night, there is nothing rubbing, the swaybar links look good, nothing torn there etc, all bolts are tight. The driveshafts look good as I say in that no torn boots, i didn't remove them when doing the struts and they sit fairly level as i thought maybe they were 'cockeyed' since the car is lowered, but they're pretty good.
Could it be something transmission related perhaps? (god I hope not)
Has anyone had anything similar?
