Workshop manual Polo 6r
  • Workshop manual Polo 6r
    Would anyone know if a workshop manual is available anywhere for 6r Polo?
    Can anyone advise me on how to remove the plastic shroud which tucks under the bottom of the windscreen and covers the strut towers? I need to gain easy access to the top strut bolts on top of towers, in view of fitting H&R springs.
    Kind regards
    VEEEUU
    Kind regards
    VEEEUU
    The pleumn chamber trim?
      Kind regards
      VEEEUU
      PM sent
      MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
      2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
        If anyone can post up the procedure for doing this i'd also love to know as I need to do this also.
        MY13 Polo GTI | 5 Door | Candy White | Sunroof & Bi-Xenon Factory Options
          Can anyone help me out? How do you remove the plastic which covers strut bolts.
            You can download a fairly comprehensive manual from ERWIN have to subscribe and pay 25 Euros for a 24 hour use and you can download all the manuals you want for just any VW. They come in sections like exterior body, Interior, Brakes, Suspension etc
            I have most of the Polo ones but not the exterior body section
              Thank hillbilly would you be able to send me one for the removal of the front struts so I don't miss anything when I change the spring. Thanks In advance
                Email me as I cant upload it to here
                  Would the exterior section cover how to replace the lower plastic panel (beneath the numberplate) on a TDi Comfortline. I damaged mine turning into a driveway too fast, and VW penrith want $300 for the part, and $170 to fit it!
                  If it seems simple enough i might attempt doing the fitting myself!
                  Cheers Guys
                  MY13 66tdi polo 'ocean blue', DSG. Comfort Pack, Sports Pack. RNS510 installed. Parking Sensors installed
                    If its the black bit with the little air dam type piece it just pushes in with clips I did a similar thing and it went back in OK
                      Yeah, its like a honeycomb sort of pattern, sort of. Its the bit under the number plate between the front fog lamps.
                      I think $170 is highway robbery for it to be fitted. Hence i'd rather attempt it myself if possible.
                      Would the workshop manual cover that or not?
                        Well by the time you pull the broken one out you will know how it goes back in I guess. It will be in the body exterior section which I haven't got.
                        I mean the undertray behind the bumper Not the lower grille
                        This might help http://www.vwwatercooled.com/forums/...how-83529.html
