Correct torque setting for sump plug
  • Correct torque setting for sump plug
    Can someone tell me this please Some say 19NM The PDF off ER Win says 30 what is it really.
    TIA
    Just do it up tight - it's not a structurally important item
      I've always come to understand the relevant specs as:
      Drain plug: 22 ft lb / 30 Nm
      Oil filter: 18 ft lb / 25 Nm
        Shouldn't be very tight at all.
        I do them up firm, but not crushing the washer into oblivion. Nip them up, and give maybe another 1/4 of a turn.
        30Nm does sound pretty close.
          I know its not but to do it up too tight on a alloy sump may cost you more than a couple of weeks wages when you strip the thread and have to replace the sump..
          VW specify a set amount of which I am unsure
          Ive owned 40+ cars so have done a fair few oil changes but always on steel sumps
          Thats why Im asking.
          Thanks to MYTHIK for a constructive answer
            M14 sump plug 30Nm
            M25 Sump Plug 50Nm
            I agree hillbilly, it might not be structural but the correct torque can mean the difference between $2 for a plug of $750 for an entire sump.
              Originally posted by gavs View Post
              M14 sump plug 30Nm
              M25 Sump Plug 50Nm
              HA HA you get your plugs cheap Mine cost $4. 91
              Which motor is the 77TSI then I did it up to 30nm. Plug Part no is N 90813202
                Measure the thread...
                  Cant its in the sump now but was a coarse thread and I didnt get the old one back
                      Will be 14mm.
                      Have repaired a few in my time, thanks to the odd bonehead.
                        It's not coares thread! It's M14x1.5
                        Coarse is M14x2
