Having a slight problem... There is an error on my dash which is a light bulb with ! In it... I've consulted my manual which suggestions there is a light out or voltage problem but if I scan the system for errors with VCDS nothing is returned..
All I've changed is allowing the horn toot with door locks and turned off fog light turn assist... If I reverse my changes the light is still there..
Just thought I'd post here incase anyone has seen it.. The light started coming on halfway through making those changes.
---------- Post added at 12:50 PM ---------- Previous post was at 11:47 AM ----------
Actually can this be deleted? I can't see a button to do so and I'll just post it in the VCDS section
