PLAN: Swap RCD310 to an RCD510.
Questions:
1. Where can I find instructions for the install?
2. Is it tricky to connect it up to the steering wheel controls?
3. How much can you sell the unused rcd310 for (guess i'm worried no-one is gonna buy it)?
4. What's the deal with codes, that is, do I need to receive a code with the rcd510 to use it (Guess the same would go for
giving a code to the person who buys the rcd310, am I right)?
5. Can you use your ipod with the rcd510 if you buy the connector cable? I may have misunderstood, but what is the point
in getting MDI for $250 factory fitted or whatever if you can buy the cable and plug it into the unit from your ipod?
Also, I'll probably check if my dealer wants to sell me an rcd510 unit since apparently they have lots of them from customers upgrading to rns510's (might get it cheaper
). Otherwise will have to get it off ebay (think it's $340).
I'm sure someone here knows the answer,
you're a legend,
Gladiator
Questions:
). Otherwise will have to get it off ebay (think it's $340). I'm sure someone here knows the answer,
you're a legend,
Gladiator
