RNS510 and 9W7 Bluetooth in new Polo 6R
  • RNS510 and 9W7 Bluetooth in new Polo 6R
    After hours of calling VW dealers in Melbourne,Sydney, and Brisbane, no one could advise me of installing proper OEM bluetooth into my new 2011 Polo 6R TDI Comfortline. Thanks to VWWatercooled I ordered all parts from eBay and the result is excellent. Not much technical knowledge needed at all.
    1) Ordering
    From polish ebay seller "used_parts_specialists".
    RNS510 "D" version (HW:H41, SW:3890, built January 2011)
    Part 1T0 035 680 D
    HW H41, SW 3890
    Bargained him down to $1000 inc shipping. The AUD is strong after all.
    Arrived in 4 days. No bent parts like other users have mentioned.
    From spanish ebay seller "bluewagen".
    9W7 Bluetooth kit (not the 9WZ which also has rSAP)
    Part 5K0 035 730 (built January 2011 - this is the successor of 7P6 035 730 C)
    $370 including microphone and cabling harness.
    Arrived in 3 days.
    2) Correcting the spanish harness
    Most likely the Spanish harness will work fine as-is, however it has the microphone connection bridged between the RNS510 and 9W7 Bluetooth. The RNS510 has a separate microphone pass-thru, so I changed the pins as detailed here:
    The Volkswagen Club of South Africa - View topic - Golf VI GTI RNS 510 and 9WZ Bluetooth Install - Long Post
    and
    Volkswagen RNS 510 Microphone Connection for voice control | my-gti.com (Option B)
    I also cut the microphone wire to make installing easier, and then rejoined it at the centre console to the piggyback harness (see point 4 below)
    3) Removing the old RCD310 system
    Follow the excellent instructions by GraveDilute, this guy is awesome.
    Particularly note the noob hint to remove any CD's first!
    More pictures here: (note this is for a Golf though! it's different but gives you some idea)
    An independent forum for Volkswagen Golf GTI enthusiasts. Forum features technical help, news, events reviews and humour! Join fellow Golf GTI owners online.
    4) Wiring the microphone
    After removing the RCD310 I wired the microphone, starting at the cabin light at the top. This all clips out very easily with minimal force. Note there is a piece of black plastic where the microphone belongs which has to be gently clipped out with a long screwdriver.
    You don't have to unscrew the sunvisor, mirror light or roof handle at all.
    Just unclip the driver side A-pillar trim buy pulling firmly starting at the top. There is no Torx screw under the Airbag logo, it's all just clips. I did this with no damage. In fact, there is not even an Airbag under the A-pillar trim I could see.
    Here is a guide for the Golf, again note it is much easier in Polo because there is no Torx screw:
    Use a long rigid wire (like solid copper electrical wire) to push the microphone cable from the dome light to where you unclipped the A-pillar trim. No need to remove the headliner at all as there is plenty of space at the front near where the headliner meets the windshield.
    Route the wire down the A-pillar, and unclip the trim at the driver's side of the dash, and again use the rigid solid copper electrical wire to push the microphone wire to the centre console where the radio was.
    5) Install RNS510 radio
    Again just follow GraveDilute's photo instructions above. I put the GPS above the air vents too, perfect spot for it. Removing the air vents required some jiggling, but it was fine. I didn't break any trim when doing this. Also remove the aircon control unit (2 screws from below, above where the cupholders are), and when you are inserting the RNS510 into the slot, you can help by pulling the extra cables away from behind the RNS510 using a hand in the aircon controller slot.
    6) 9W7 Bluetooth module
    I have the comfortpack climatic controls and the Bluetooth module fits perfectly behind the controls. This may/will not work if you have standard aircon controls, and you will have to route the module to under the seat.
    See here: http://www.vwwatercooled.org.au/f78/...tml#post647845
    Issues:
    - None really. Bluetooth and DVD Region playback work out of the box. No need for VAGCOM/VCDS coding.
    -A2DP Stereo streaming with iPhone 4. Full addressbook download in under 1 minute. No issues.
    - The non-GTI Polo's have a cheap midline MFD in the dash cluster, so you don't see any song or Bluetooth or any info at all. To pair the Bluetooth, the module is "discoverable" as soon as you turn the ignition on, PIN code for me was 0000 not 1234, so you don't need the highline MFD to pair.
    - The standard steering controls work without coding. The telephone and voice control buttons don't.
    - The "star" button on the RNS510 allow voice control. The steering wheel button for voice control stays as mute until you code with VCDS.
    An awesome way to spend ~$1400 AUD. Think of the added safety with Bluetooth too!
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    Thanks for the write up and links.
      I'm planning on getting this same Bluetooth kit from eBay, I'm thinking of doing it myself but I'm worried about programming the MFD and such. Really don't want to pay VW $800 for Bluetooth! :O
      2011 Polo GTI 5 door Candy White
      H&R Springs/APR Stage 1/OZ Racing Superturismo GT's
        I don't really think you have a choice given that the dealers flat out refuse to fit the proper bluetooth module 5K0 035 730, stating it is a "Golf" part. All the dealers I spoke to offered an aftermarket FISCON system or the tack-on universal VW kit, part number 000 051 473A. Link: Volkswagen Accessories - Bluetooth hands-free system
        Your best bet may be to order the part from ebay and get an independent service person to install / program it.
          Just wondering how much work will need to get done for coding of the RNS510 with the aforementioned fiscon bluetooth kit, ive got my polo coming in the next couple of weeks and am seriously (already) thinking of replacing the rcd510 with the RNS and i havnt even gotten it yet haha.
          Basically i know nothing about the whole VAG-COM side of things and was wondering how much effort was involved
            If you get the OEM VW units I mention above (not the FISCON aftermarket bluetooth kit) then you need no Vag-Com coding at all. In the non-GTI Polo's you don't get a highline dashboard cluster MDI display anyway, so no point in coding that, and also most people prefer to keep the steering wheel button as "mute", since you can always press the voice control button on the RNS510 unit itself.
            In summary in a non-GTI Polo coding is unnecessary. Only needed if you have a GTI and want the dash MDI display to work with the RNS510, or if you want the steering button to activate voice control rather than mute.
            Hope that makes sense.
              I wonder how many "bluetooth installers" would be able to do the coding though. I'll have to call around, i know my local car audio place fit bluetooth but i'm not sure if they could do that coding.
                Hey GraveDilute, the pictures on your polo install arent showing :|
                  Hey guys,
                  I'm getting the RCD 510 on mine, from your experiences, is there any reason this won't fit?
                  KIT Bluetooth VW RNS 510 9W7 5K0035730A 5K0 035 730 A B | eBay
                  Have asked the question for discount qtys for a potential group buy....
                    Hey Gav, the listing has been removed on Ebay. May need a new link buddy.
                    2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
                    MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
                      Just wanted to clarify, you cannot answer calls from the steering wheel? Where do you answer them then? Can this be done on the RNS510 or must it be done on the phone?
                      P.S. Anyone have any luck paying for an install on an RNS510 and/or 9W7?
                        That is correct, the module needs to be activated for the buttons to work via VAGCOM.
                          What is the most cost-effective way to have that done? Will a dealer do it for you?
                            Unless you are mates, they might bit*h about it if it's not the unit they would fit or the factory installed unit. Otherwise, find someone on here that has one to give it a try for you or see if you can borrow theirs You will need to make sure it is the latest version of teh Ross-Tech software though...
                              Hey guys, does anyone know if it's possible to access your phone contacts via Bluetooth on the Polo standard fit stereo? I'm struggling to find out if it's possible. Answering calls isn't a problem, works fine. Just wondering if the contacts is possible?
                              BMW Z4 (2019)
                              Audi TT quattro (2015), s-line in Nano Grey - sold
