Originally posted by markwid
View Post
New engine running-in?
Originally posted by noone View PostEither of the Syd boys breaking in a GTI? I'd love to come for a bit of a drive with you if you don't mind going an older brother raging along (9n3GTI)
If you have time, kuringai park to old Pacifc hwy is always fun2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
Originally posted by Crispy View PostHi all.
Just recently picked up a new polo. The dealer said there were no specific requirements in terms of breaking in the new engine.
My brother-in-law told me to drive it fairly hard, and constantly vary my speed for the first 1000 kms with no cruise control.
I have tried to find some documentation without success.
Any ideas?
The main thing is not to stress about it, all you want to do is exercise the motor. Just go easy on the throttle before the engine is up to operating temperature. After that use the throttle as necessary, but avoid babying it excessively or using full throttle *all* the time.
And there's no need to change the oil at 1k or use mineral oil or whatever. Letting the factory fill (most likely to be a synthetic oil) run until the first scheduled service should allow the motor to wear in gradually and nicely. Just keep an eye on the oil level, top-up if necessary (with 504 oil) and be sure to follow the distance or time interval (whichever you reach first) to the letter.
Happy motoring.
Originally posted by stucam View PostThanks for the route. Looks promising. Is this a trip you have taken kaanage? Cheers, S.Last edited by kaanage; 30-01-2011, 01:31 AM.Resident grumpy old fart
Originally posted by pologti18t View PostLook up Wollombi on Whereis.com and drive there.
So, which is more dangerous? Single lane, two way that keeps you entertained and alert or 3 lane freeway that puts you to sleep?2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
I see that Penrite do a mineral 5w30 oil.
Apparently the VW recommended oils have a low Sulphated Ash content.
Would it hurt using a non VW recommended oil like the mineral 5w30 for the first 1000km to run in?
Thanks2011 Tiguan 147 TSI - Pepper Grey - Sat Nav - RVC - Bluetooth - 18" NY
Thanks
- Using mineral oil in an engine that calls for synthetic oil as a minimum (as implied by VW spec 502.00 or 504.00) would be unwise.
- VW warns of risk of engine damage otherwise (may or may not be mentioned in the owner's handbook).
- VW would not look kindly on engine-related warranty claims should they discover you replaced the factory fill oil with an unapproved oil (mineral or otherwise) for the first 1,000 km.
- Engine and lubricant technology is constantly evolving, though we sometimes struggle to keep up to date.
ThanksPerformance Tunes from $850Wrecking RS OCTAVIA 2 Link
Thanks Diesel_vert & Transporter, after reading the "run-in secrets" article that seems to be mentioned a bit on the forum, i thought i would see if anyone else had gone that step further and put mineral oil in.
Transporter, how did the oil look? is the filter easy to access on the Tig?(off topic I Know) still waiting on mine to arrive.
Might be an idea to use a magnetic oil pan nut after 1st oil change.2011 Tiguan 147 TSI - Pepper Grey - Sat Nav - RVC - Bluetooth - 18" NY
I can't understand why anyone wouldn't take the easy road & follow the mfrs recomendations.
My run-in process was 45km of motorway on the way home from the dealer. 3rd gear - accelerate on half throttle up to about 110kmh then let it over-run back down to about 70kmh. Did that all the way home.
The next day I did a 400km round trip down the coast with the family on board. They would have spewed (both literally & figuratively) if I'd done the accelerate/decelerate process, so I just kept the revs between 2000-4000 and didn't bother with 6th gear. Changed the oil at 15,000km. Now at 70,000km - no oil usage, good power, good economy.
re: magnetic oil pan nut. What's the point if the car has an oil filter on it?carandimage The place where Off-Topic is On-Topic
