Polo 6C: doors felt noise (creaking)
  • Polo 6C: doors felt noise (creaking)
    Hello boys !
    I'm currently the owner of a Polo 6C from 2014 (June) with a 1.2 TSI engine (manual gearbox) in Cup finition.
    It's a special on based on "Confortline".
    Few months ago I decided to clean up the felt on my door and the rubber seals too.
    I take an APC diluted at 1/4 and take a brush to clean.
    I remove the excess with a microfiber.
    When I took the car I was scared by the ammount of creaking noise. The impression of driving a 50 years old car.
    I made some research and apparently it's a common issue on Golf MK 6 and MK 7 and Polo of the same year.
    Creaking noises appears for no reason. For me I think APC is the cause.
    Then I decided to clean up the rubber (I tough It was them and not the felt) with alcool (95°) and rince them with water and dry them with a micro fiber.
    After I applied the rubber care of VW on rubber seals: 000096310B
    Creaking noises still present.
    I decided to treat the felt with this product. Creaking noises were eliminated at 95% I was quite happy.
    But they came back few days later.
    Today I deciced to clean up the felt to remove the APC and the rubber care product.
    Hot water in spray, I brush them with a soft brush and rince with water anb a microfiber.
    I did this only on the driver's side door to test different method.
    I will try the Gummi Pflege. If the water cleaning solution will not work.
    Other people talk about the Krytox (VW reference: G052172M2 // G052172A2)
    Does anyone have an opinion ?
    This is the stuff I used on my Mk7 Golf. Spray on some cloth and wiped around the rubber seals and also were the seal touched the paint...worked a treat.
      Thanks for your help.
      I will try it. But how long it is effective ?
        Applied it about 10 months ago and it is still quiet, I plan on doing it again in December when the next service is due.
          You can try lubricating the door seals with something like Krytox 105.
