6C GTI Front end clunk noises
  • 6C GTI Front end clunk noises
    Hi
    I have a 6C GTI and am getting loud clunk noises from front end both sides (sounds like something to do with suspension) when going over bumps but mostly when backing out of driveway with steering turned.
    Also getting faint clunk when steering full lock to the left.
    not sure if these two are related.
    Any help would be appreciated
    Stage 2 Manual Polo GTI 6C, Stage 1 Amarok V6 x2, Mk1 Golf 1.8t 20v swapped
    Loose subframe bolts maybe, I'd start by checking them first.
    Gary
    Golf Mk7.5 R, Volvo S60 Polestar, Skyline R32GTST
      ok thanks m8
      where would i locate them?
        Originally posted by kentwbird View Post
        ok thanks m8
        They bolt the subframe to the chassis, vertically. So it's an under the car job, with a tension wrench, sockets and a long extension to get to the bolts that go through the subframe. The subframe location is mildly adjustable which mostly affects the camber, side to side. So a wheel alignment afterwards to make sure that it is the best position, so the camber is even side to side.
        Gary
          Front pads moving around in calipers when moving backwards. Normal
          MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
          T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
