Hello!
My Polo has climate control. A couple weeks back the cabin fan sounded like it was pulsing and there was a faint clicking every second from behind the glovebox. I took the glovebox out and made the following observations:
Could someone please give any ideas on what the problem could be? Actuator, cabling, ?
Thank you!
- Only happens when set to fresh intake. When recirculating there are no issues.
- The issue is intermittent, but happens more than it doesn't.
- Fan works no problem at any speed.
- What appears to be the fresh air intake actuator continually cycles as though its trying to open or move, but can't - this is the clicking noise and can be seen in the below video.
- The cycling does impact the airflow which is the airflow pulsing sound.
- The actuator continues to cycle even when fan is turned off.
- Wriggling the cable that plugs into the actuator only once seemed to make the actuator cycle quicker and do random things. I couldn't reproduce this again - so could've been a coincidence.
- The AC, heating, climate control works fine.
- I tried bending and wriggling the actuator cable all along it and couldn't make the actuator stop cycling or start cycling.
Thank you!
