Location of oil temperature sensor (1.4 Polo Gti)?
  • Location of oil temperature sensor (1.4 Polo Gti)?
    Does anyone know the location of the oil temperature sensor? Is it integrated into the oil level sensor on the base of the engine or is it a seperate sensor (resistance type bolt)?
    I've getting 'Oil Sensor - Workshop' warnings and my oil temperature readout is all over the place. Oil level is fine.
    if its the same part number as the polo 9n3 gti's then its in the oil level sensor. Mine is a 3 wire but handles temp and level apparently. level goes to the dash and temp to the ecu but dont know how its used by the ecu. If you can get a part number off yours i'll compare it to mine to confirm if you want.
      The part number is 1J0907660F and from what I can gather online it also acts as a temperature sensor.
