Yeah the DSG getting slippy real quick
  • Yeah the DSG getting slippy real quick
    Hi all
    Just a quick post on my 132TSI 7-spd DSG
    The car done less than 4000kms and I felt DSG shuttering and slipping.
    Sad~
    Neal
    Please give an account of the circumstances under which it happened.I will try to replicate the situation and see if it happens on my car
      Interesting. My wife's 132TSI has done triple those kays without a hint of an issue. (Goes in for it's first service next week)
        Try a cold start or drive up hill.
        Watch the rpm dial. It jumps and the car shakes.
          Probably the DSG need a reset.
          I have no idea
            I have not faced any DSG jerks during any of the situations.
            When you stop on a hill and then start do you use the autohold feature?The autohold is a much better option than trying to hold the car by just biting the DSG
              Hi all
              Sad~
              Neal
              Neal, you have started a number of threads with issues with your Passat.
              Have you taken it to VW yet?
              They might sort it all out for you...
                Just a heads up but if you drive it like a slush box it will get slippy really quickly
                EG trying to hold it on a hill using the throttle like in an old auto Creeping in traffic by lightening off on the brake pedal and letting it move forward.
                THE DSG IS NOT AN AUTO It is basically a manual gearbox with two electronically controlled clutches One works 1,3 5 ,7 and the other works 2,4,6
                Therefore if you do any of the above it is similar to slipping the clutch in a manual and may be accompanied by suitable burning smells.
                  No I havent
                  I just want to give some feedback and discussion on this forum and see how the others go
                  I may ask dealer to fix all the issues together later on as the car is still pretty new and drivable..
                    Yep those are good advices.
                    I basically want to see how the car improved from my 2013 Golf mk7
                    However, DSG are all quite easy to break in my opinion. Whichever dry or wet, it burns the clutch pads.
                    I do have extended warranty so I dont mind those issues too much.
                    Dealer will always give it a new clutch pad but It is just quite annoying that you need to fix the clutch like every year.
                    Anyway I will keep an eye on it then maybe fix the issues with dealer one day.
                      If you drive it properly you shouldnt need clutches every year ever.
                      Drive it like you own it, not like you stole it
                        If you need to replace the clutch pack every year, the problem is likely with the driver, not the vehicle.
                          Really!! every year.... glad i'm not buying a used car off you
                          Tell me do you add oil only when warning light comes on then think oh engine is making funny noises bad vw workmanship
                          I have a 140k+ 9 year old 6 speed wet dsg in my highline i know how to drive it still works like new
                          Wife has a polo with the so called horror 7 speed dry clutch i taught her how to drive it 55k and still like new no shudders clunking ect
                          Daughter is getting highline when my new car(7 speed wet dsg) arrives i have taught her how to drive it looking forward to many more trouble free years
                          Please do not blame gearbox for your own bad driving issues
                          2017 Golf Alltrack 135tdi All options
                            You better teach me how to drive then!
                            Looking forward to your lesson.
                              The message that you don't seem to be getting is that perhaps you should be looking at the way you drive, instead of simply blaming the machinery.
                              But of course, it MUST be the machinery, mustn't it. There could NEVER be anything wrong with the way you are treating it could there?
                              In the end, someone can only be helped if they are willing to accept that help.
